Cutting rods
fisherman_baboo
So
I've got 2 purglas rods, both 1 piece.
A guy at the tackle shop told me that they're too big to be practical and if it were him, he'd get them cut.
My question to the experts, how does this work?
Can the 4.2m single piece rod, be converted into a practical 2 or 3 piece?
How much would it cost?
Ninja-Nic
Hey Baboo, not sure how this works, but a mate of mine's old man shortened the end of his surf rod so he could use it in a bucket- the reel was too far up the rod for his short arms to operate it properly. I'll ask the ballie and see what he says, then let you know.
You could make a spigot for it. I think it's called a spigot. Basically you need another piece of rod/blank that will fit snug into your blank. Then you epoxi it into one of the sections.
Abaddon
One name for you here - ENIGMA ..
Will have all your answers.
I also think the guy may have been implying you shorten the rod - take some off the base and a little off the tip. It will change the action somewhat and I am not sure if this is what you are wanting.
kitefisher
Hi There
Bennie's got a good idea if you really really need to have them multi-piece.Unfortunately you may need possibly costly professional help to make them multi-piece,and it may be uneconomical.
Multipiece(more specifically the older type two-piece) Purglas rods(as possibly others too) have re-inforcing/extra wrappings/layers near the joints for obvious reasons.Seek professsional help(like Enigma) for the above,and do the maths thoroughly.
If indeed you merely want to shorten the existing length for possible ease of cast and more leverage(debatable) when playing fish(i.e 350/ is a very forgiving length), then I recommend you do it from the butt-side only,especially on the older Purglas rods.The reason being, is that the manufacturer back in the day, used the same length mandrel to manufacture a 400,375,365,350 and possibly even the 300 length rods.They simply shortened the rod/blank from the butt side to build the abovementioned length rods.Bear in mind that Purglas allowed for the shortening with ample wraps along the whole but section.The tip side in comparison has a very thick wand-thickness, which increases as the tip gets thinner.(the actual thickness of the wand that is)
Bottom,line is, although it has been done by some,it is not advisable to shorten a Purglas(older model) from the tip-side,as the wand-thicknes/amount of layers, decreases rapidly as you move further from the tip,which could lead to breakage when shortening your Purglas from that side,and fitting your tip-guide on a thinner wand than it should be.
My advice:keep them one-piece as long as transport is not a major hiccup(shouldn't be, you live at the coast),possibly shorten one first, to get the feel(or cast a mate's 375 or 350 length in the same stroke as yours,i.e /1,2,3,4 or 5)
Lots of fish were caught one those ''too big rods''and probably would still be today, if the crime scene did not necessatate rods to be locked away in car-boots.
Joker
You could shorten the rod from the butt section. It works. Take a look under rods DIY.
BigT used a 400/2 and cut it back to get a 12.6'. He says he likes the action.
Enigma has answered this question. It can be done. No come backs and its nogal costly if done expertly.
