Cup-faced poppers
The way they get a mullet on lure is a mepps type spinner, a little trailer hook on a 2" piece of thin flouro and baited with a worm..You're gonna have to tell us which worm works. Maybe use a powerbait worm for a pure artlure attack?
You probably just foul hooked those springers because they were so thick, if you want a popper to foul hook them, why use a popper, just gaff em with a gang of trailing trebles, not much sport though and probably illegal for good reason haha..Ja spinner to get em to follow and worm for em to bite, that is the sporting way I reckon..been discussed on here before.
http://www.anglersmail.co.uk/fishing-tips/fish-fishing-tips/mullet-and-how-to-catch-the-thin-lipped-variety-24324
G
Guest
Guest
The topic of mullet on lures is an interesting one.
The guys in Knysna are catching them regularly now on surface lures when targeting grunters. It is the big striped mullet with some exceeding 2kgs and getting close to 3kg. Very good fun as they are turbo charged.
Interesting things mullet - I was fishing Robberg in March with a mate that spends at least 40 days a year there looking for some form of gamefish.
We were sitting between the gap and the point and I saw a patch of fish moving along the ledge below. I jumped up and made a cast thinking that it was a patch a smaller tail. My mate nearly fell off the rock laughing. I had just got excited by a shoal of mullet. those things he had seen every day that he was there for nearly 2 months. In my defence all of the fish in the shoal exceeded 5 kg. None were interested in what I threw at them.
Regards
Anton
EugeneC
No need for worms. I’ve caught plenty mullet on DUO bay ruf manic lures in the past. Never targeted them on the surface, but I’m sure if you kept at it you can figure them out. The bay rufs are not far away from being surface lures anyway. Another way is to use a small white death fly with a small split shot crimped 10cm or so above the fly.
The bigger ones are just plain weird fish. I’ve had them attack 12cm stickbaits before and like Haakies I got very excited once in Oman when I came across what I thought at first was a big school of large shad, only to be disappointed the same way as well. They can be very aggressive at times, but mostly they’re frustrating like milkies.
Limpopoking
I've never targeted them other than when I was a kid and we tried, unsuccessfully, to catch them with termites on a tiny hook in the rivers at the Kleinemonde... My gut feel is that the most successful way of catching them on artificials would be with a fly... That could be quite a jol.
duckbill
Hey
It looks like the fish are scared of the Halco Roosta. I didn't get a single chase on it the entire holiday, but at least i got a few leeries on small stickbaits and my little Heddon topwater lure.
duckbill
Dear Sealiners
I finally got to enjoy some leerie action on the 6cm Halco Roosta Popper.
December 2019, one leerie of about 45cm and later that day a 71cm leerie.
Earlier this year 8 young leeries in a session and about a week later another 3 leeries. All on the little Halco Roosta.
My total for about 7 trips is 58 leeries on various topwater lures and the smallest CID Shiverstick.
Thanks for all the tips.
Fly-aholic
duckbill wrote:
Dear guys
I set myself the goal of catching an estuarine garrick or shad on my brand new Halco Roosta Popper. I need a little bit of advice as I know very little about popping.
I've caught plenty of garrick and a few shad on stickbaits and walk-the-dog type lures, using a loop knot.
My question is around the retrieve one would use to fish these poppers. Should it be retrieved using a side to side action, and hence attaching it to the leader by means a loop knot? Or will a normal retrieve, i.e., reeling it straigt in like a plug, and using a figure eight knot, be best?
Your input will be highly appreciated.
Duckbill
Everything the guys are saying below has relevance to catching Leeries on Rooster Popper. This is my take on it:
What size popper do you have? Anything smaller than a 135mm viz. 80 and 105mm I will not use a lure clip, but a Rapala knot. Especially that you have good experience with walk-the-dog type lures, you can make the popper to that too.
With poppers, unlike more imitative lures that resembles specific baitfish or prawns and are paused, a popper is more suggestive than imitative.
So for specifically Elf and Leeries, I would suggest to NEVER pause the popper. Keep a steady retrieve with the occasional splash by flicking your wrist as you would for walk-the-lures. For aggressive fish that are 'turned on' by movement and splash like Elf and Leeries, never stop moving the popper. With my 3000 Daiwa BG, I continuously reel at about a turn per second with the occasional splash, but I never stop. To many times you have a Leervis or Elf following the lure and turn away when you either slow down or stop the lure. When I see a follow and no reaction bite I will increase the retrieve with more splashes to hide the general appearance of a popper. In low light the shape does not matter much as they concentrate more on the movement, but during the day, hide the 'awful' shape of the popper by keep retrieving and splashing occasionally.
With 135mm poppers I will add a lure clip for ease of changing lures if the popper does not work. Many may argue that due to the continuous movement and splashing the bait clip does not impact on the action of the lure, that might be true, however I prefer a nylon (floats) that is dull with 1000 grit sanding paper to remove the shine, same goes for walk-the-dog lures.
If you are hell bent on catching with a Rooster Popper then keep is moving, always. No follows or strikes, move on to next spot.
If you have follows and no takers, speed up retrieve. If this does not work then popper is not the 'flavour' of the day.
My 2cents, happy hunting!
