duckbill wrote:
Dear guys
I set myself the goal of catching an estuarine garrick or shad on my brand new Halco Roosta Popper. I need a little bit of advice as I know very little about popping.
I've caught plenty of garrick and a few shad on stickbaits and walk-the-dog type lures, using a loop knot.
My question is around the retrieve one would use to fish these poppers. Should it be retrieved using a side to side action, and hence attaching it to the leader by means a loop knot? Or will a normal retrieve, i.e., reeling it straigt in like a plug, and using a figure eight knot, be best?
Your input will be highly appreciated.
Duckbill
Everything the guys are saying below has relevance to catching Leeries on Rooster Popper. This is my take on it:
What size popper do you have? Anything smaller than a 135mm viz. 80 and 105mm I will not use a lure clip, but a Rapala knot. Especially that you have good experience with walk-the-dog type lures, you can make the popper to that too.
With poppers, unlike more imitative lures that resembles specific baitfish or prawns and are paused, a popper is more suggestive than imitative.
So for specifically Elf and Leeries, I would suggest to NEVER pause the popper. Keep a steady retrieve with the occasional splash by flicking your wrist as you would for walk-the-lures. For aggressive fish that are 'turned on' by movement and splash like Elf and Leeries, never stop moving the popper. With my 3000 Daiwa BG, I continuously reel at about a turn per second with the occasional splash, but I never stop. To many times you have a Leervis or Elf following the lure and turn away when you either slow down or stop the lure. When I see a follow and no reaction bite I will increase the retrieve with more splashes to hide the general appearance of a popper. In low light the shape does not matter much as they concentrate more on the movement, but during the day, hide the 'awful' shape of the popper by keep retrieving and splashing occasionally.
With 135mm poppers I will add a lure clip for ease of changing lures if the popper does not work. Many may argue that due to the continuous movement and splashing the bait clip does not impact on the action of the lure, that might be true, however I prefer a nylon (floats) that is dull with 1000 grit sanding paper to remove the shine, same goes for walk-the-dog lures.
If you are hell bent on catching with a Rooster Popper then keep is moving, always. No follows or strikes, move on to next spot.
If you have follows and no takers, speed up retrieve. If this does not work then popper is not the 'flavour' of the day.
My 2cents, happy hunting!
