Crimping piano wire
G
Guest
Guest
Hi there
Does anyone know if you can use crimping sleeves on piano wire.  I've only ever seen it used on carbon / nylon coated multi-strand wire, but never on single strand piano wire eg. American Toothproof?  Anyone know why not?
I have only seen the Haywire Twist used on piano wire.  But crimping sleeves would make life so much easier.   With the Haywire Twist you never get all your traces the same length, you often end up with a kink at the end and also sometimes get the fine end stuck into your fingers.  Ouch!  So why not crimping sleeves - so much easier and faster.
Also, has anyone come accross American Toothproof "Titanium" wire.  I have seen it advertised on the back of Toothproof packs and it is supposed to be elastic, kinkproof, etc, but I have never seen it in any tackle shops.
Cheers, Gilly
Chambeshi
Hi Gilly
A friend and I have used Toothproof Titanium-Nickel trace trying for goliath tigerfish in the Congo. It is about R150 per 3m!! But being thinner hopefully less visible, and above all very unlikely to kink...especially with n+ kgs of seriously pissed-off goliath on the other end.
The 70 Ilb B/strain stuff we used handled a ~15kg goliath no problem, but has yet to be tested fully. Fred Tucker's here in Cape Town ordered it from J'burg.
This titanium wire pulls through sleeves, even if crimped very tight with proper pliers! The packaging says one can use a blood knot but it is very tricky to tie (hence bad press on some discussion groups). But the best knot is a Non-slip loop (illustrated pages 66-67 in a recent book "Fishing Knots: Proven to Work for Light Tackle and Fly Fishing" by Lefty Kreh 2007.)
even better try this link [appended below] on google books which illustrates those particular pages :)
Some fly fishermen swear by these titanium-nickel traces especially as they don't kink. Actually a remarkable alloy, but go carefully, if one does manage to kink it (quite a mission with pliers) then it snaps very easily.
cheers
http://books.google.co.za/books?id=YxnU3Ggj1DoC&pg=PA66&lpg=PA66&dq=titanium+nickel+wire+fish&source=web&ots=B4dZyeT8IQ&sig=ZgPTJAECEXkTGJS3qYf-YyXERys&hl=en&sa=X&oi=book_result&resnum=7&ct=result#PPA66,M1
