Hi there,
If you take a drive down towards Kommetjie..you can catch them from the rocks using a pole or old fishing rod..piece of snoek line and a stocking filled with limpts or fish bait... dip the stocking in to the bamboos you see around you and wait for a while then pull up slowley and you should have one or two stuck to the stocking... make sure you have a net with you..so they dont drop off. Try behind the lighthouse,Soetwater, and Cape point. Make sure you bring a wet suit pants as the water gets cold and you have your permit for crayfish and bait avalible.
Hope this helps you... good catching...
