In Durbs this crab is commonly referred to as the Moon Devi. They're most abundant at night, but as Strandloper pointed out, can only be removed during the day. Your best bet would be to target them at sunrise, when a few are still on the rocks. Here stealth is the key and one can often catch them by hand.
Later in the day, a technique for catching them that I'm not too fond involves the use of a thin strong wire with a bent tip section. Since you cannot see the whole crab until it is out of its hiding place, you can't tell whether the crab you are pulling is in berry or not. This method often kills crabs in berry so I'm not too certain how legal it is. The other methods I've seen are much more destructive and definately NOT advisable. It's not usually necessary to take more than 3 for an outing. As others have said, If there is a musclecracker in the area...
I've never tried or seen anybody supergluing a crab with successful results. (This doesn't mean it won't work)
I wouldn't try it with this crab when targeting musclecracker for two reasons:
1. Humans have a comparatively weak sense of smell. Superglue has a pretty strong smell. I suspect the fish would be able to smell the superglue even when we no longer can.
2. This crab makes its home in crevices on and under rocks. If it has the opportunity to scuttle around under water and its gonna head straight for these.
3. When targeting musclecracker in the surf zone, you'd cast your bait into or on the edge of turbulent/working water right between the rocks. Your bait is going to be washed around quite a bit, so keeping it alive " for more movement" may not be necessary
As for hooking:
1. Through the 2nd leg slot in the carapace similar to that shown by frank 22.
2. Alternatively lift the protective flab at the back, thread hook there and out through the mouth.
3. Another good way of doing this would be to cut open the carapace from just below the eyes, front to back, about 3/5 into the crab. Lay your hook (shank and eye) in the crab and close the carapace. Secure well with your bait cotton (being sure NOT to cover the entire carapace with it).
Those red rubber bands that you get CNA can also be used for this.
I suspect that the 3rd method would get the most scent in the water.
