Conventional reel Vs Spinning
BeachRunner
I most often fish a Seven foot spinning setup as I prefer close quarters surf fishing and on the occasion a bit of drop shot. As a result I have not had or needed much experience with a Conventional reel.
What are the pro's of using a conventional reel (aka multiplier) as opposed to a spinning reel (aka open faced or coffee grinder) reel?
BluFlu
Right let's see:
Spinning:
Advantages
  • Easy to use[/*]
  • Relatively more drag for the same size reels
Disadvantages
  • For the same bang generally more bucks i.e. a good spinning reel is generally more expensive than a good multiplier[/*]
  • Lower line capcity than the equivalent multiplier although generally overcome by spooling with braid.
Multiplier
Advantages
  • More line capacity[/*]
  • Better in the heavy duty casting applications such as surf fishing due to casting action and not having to try and control the line under huge tension with ones finger[/*]
  • Generally less buck for the same bang.
Disadvantages
  • More difficult to cast as a result of the ever present chance of an overwind and having to get the spool to turn makes it a challenge with lighter lures.[/*]
  • Less drag like for like
With a 7 foot rod I would suggest spooling with braid and using a spinning reel. The baits and lure you will be casting will be light and you will struggle to get the same distance with a multiplier. It is also far less hassle.
