Whilst awaiting my hollow core spectra shipment I did some searching on the web for uses, other than Windon connectors. The ideal is taking hollowcore as a mainline and just inserting the leader into the braid and a quick tie off and you're done.
Needless to say I was most excited by the application of hollowcore in securing topshot to a backing.
Today I spent a few hours practicing and tesing the connection and looking for alternatives and improvements.
What do you need:
Blunt darning needle (although a large sewing needle can be used)
0.67mm DaHo hollow splicing needle
Floss
Spectra Adhesive or Q-Bond super glue
100 or 130lbs hollow core Spectra.
Cut off a 50cm length of hollow core. Run it between thumb and index finger nails to loosen the thread and prepare it for threading.
Thread your sewing needle, if a blunt darning needle then inset it point first and thread it and the braid backing through the hollow core.
What do you need:
Floss
