DieterW wrote:
maybe I am really stupid..............
most of the time when fish take a slide bait the rod it in the rod stand.......right.
in the rod stand the drag is set loose enough so that when a fish comes around and take the bait that he can run with it without pulling the rod over and into the sea, but yet tight enough so that the current(if any)does not take any line.........right
so when fish takes your bait and runs with it, one of two things has happened he taking line but your sinker is still 'vas' in the sea bed or you sinker has become dislogged(in which case the non return should be at your stopper ring and no thread of burn off (from the non return)exist........right, but in the first case burn of could very well happened, in this case only thing to do is to tighten drag slightly and evenly and hoping that sinker will either break off or become dislogged, if the sinker does not break off or become dislogged and drag get too tight too quickly you will get burned off.........right.
if the fish is in 100meter the difference in the hight in the line will be 50% in deference, but in meters hardly anything.
for me any upright rod is a shock absorber to take or release tention on the line and if you straight stick..........you got less feeling as to what is happening at the end of the line.
guys I am not trying to be difficult, I always take advice from anyone but will always analyse it and if it does not make sense to me in a practical sense not use it.........has it not become part of the show when fighting a big fish, like the guys running up and down the beach for no reason.............:
op::
op:
Burnoff come from friction between the sliding ring and your line. The tighter your line the hotter the contact point becomes.
When the rod is held upright the friction between the rod eyes and the line adds more tension to your main line. By dropping the rod this tension is removed thereby removing tension from your mainline.
This is how i understand the physics of it.
