combination swivel
Simen
bradles wrote:
Simen wrote:
Red -- main line
Blue -- hook line
Green --- sinker line
Also see: http://www.sealine.co.za/view_topic.php?id=41812&forum_id=57&page=1
Just replace the single swivel with the combination swivel and tie the lines as to the above colour.
I prefer to have it setup like this.
Red - Main line
Blue - Sinker line
Green Hook line
My reasoning behind that is I would rather the strain being on the one swivel.
I understand your reasoning, but think of it this way.
If you have your mainline and your sinker line in a straight line (pulled tight), it allows the other ring (swivel) to have freedom and give your bait movement in the water.
Having it your way you actually kink the line, and the two rings work against each other, so when you have your sinker roll on the bottom the chance of having your hook line roll up onto your sinker line is increased.
Also less strain on the connection of the two swivels (angle) when casting
(Not saying you are wrong just my reasoning)
bradles
That makes sense also
I have been rigging my rigs as i described and haven't yet had any issues.
However I will keep your reasoning in mind should anything change
Simen
I am going fishing this weekend, and going to give your set up a try, also thinking of it what you say makes sense.
FLUKE
Simen wrote:
bradles wrote:
Simen wrote:
Red -- main line
Blue -- hook line
Red - Main line
Blue - Sinker line
Green Hook line
With combination swivels both ways are a compromise IMO.
If I'm fishing anywhere that my sinker is rolling I fish a sliding sinker as there is much better sensitivity and the fish can take line without moving the sinker, so I stick to a loose swivel sliding on my main line/leader and a power swivel joining my leader and hook snood.
If I'm fishing where my sinker could get hooked up I use a fixed sinker so the fish can pull it out or I can snap off without loosing the fish. In these areas the sinker will seldom roll far before it hooks up. For the fixed rig I tie my leader and sinker line to the same loop on the swivel and tie the hook snood to the free swivel loop.
As a result of these two predominent styles of fishing I don't have a need to compromise by using a combination swivel. That's just my humble opinion though and whatever makes you confident without twisted up lines is the right way:fishn
Simen
FLUKE wrote:
Simen wrote:
bradles wrote:
Simen wrote:
Red -- main line
Blue -- hook line
Red - Main line
Blue - Sinker line
Green Hook line
Agree with you, use very much the same system when using a single swivel.
Maestro
I agree with Simen, the smaller swivel has the ability to rotate 360 degrees and thus allows your bait movement in the water with your sinker line being fixed.It also helps to keep your bait off the ground when tension is applied to the sinker line. By tying the hook line to the small rotating swivel, it largely reduces the chance of the line becoming wrapped around the sinker line as is often the case when using 3 way swivels and if you tie the sinker line to the small, rotating swivel,there is a greater chance of becoming wrapped when it rotates. Also, when tying multiple hooks using 2 power swivels,you would tie the hook on the small rotating swivels and not onto the big ones. This is how a distributor of the power swivel had explained it to me and how the compo guys here use it.
