STEALTH 225
got myself a few comb.swivels, but not sure what to attach where. any eg on traces would also help alot.
Red -- main line
Blue -- hook line
Green --- sinker line
Also see: http://www.sealine.co.za/view_topic.php?id=41812&forum_id=57&page=1
Just replace the single swivel with the combination swivel and tie the lines as to the above colour.
Simen wrote:Red -- main line
Blue -- hook line
I prefer to have it setup like this.
Red - Main line
Blue - Sinker line
Green Hook line
My reasoning behind that is I would rather the strain being on the one swivel.
With combination swivels both ways are a compromise IMO.bradles wrote:Simen wrote:Red -- main line
Blue -- hook line
Red - Main line
Blue - Sinker line
Green Hook line
I understand your reasoning, but think of it this way.
If you have your mainline and your sinker line in a straight line (pulled tight), it allows the other ring (swivel) to have freedom and give your bait movement in the water.
Having it your way you actually kink the line, and the two rings work against each other, so when you have your sinker roll on the bottom the chance of having your hook line roll up onto your sinker line is increased.
Also less strain on the connection of the two swivels (angle) when casting
(Not saying you are wrong just my reasoning)
Simen wrote:With combination swivels both ways are a compromise IMO.bradles wrote:Simen wrote:Red -- main line
Blue -- hook line
Red - Main line
Blue - Sinker line
Green Hook line
If I'm fishing anywhere that my sinker is rolling I fish a sliding sinker as there is much better sensitivity and the fish can take line without moving the sinker, so I stick to a loose swivel sliding on my main line/leader and a power swivel joining my leader and hook snood.
If I'm fishing where my sinker could get hooked up I use a fixed sinker so the fish can pull it out or I can snap off without loosing the fish. In these areas the sinker will seldom roll far before it hooks up. For the fixed rig I tie my leader and sinker line to the same loop on the swivel and tie the hook snood to the free swivel loop.
As a result of these two predominent styles of fishing I don't have a need to compromise by using a combination swivel. That's just my humble opinion though and whatever makes you confident without twisted up lines is the right way:fishn
