Cold front moving south and high pressure coming i
Psy
Cold front moving south and high pressure coming in, sand has opened new holes within the reserve, whats the verdict? Going to check it out!
See you on the beach.
:) :fishn
Beach conditions did change - good 6 foot of sand has been washed to the sea. Good catches were done at Oyster beds.(not by me)
Psy
9~10 April 16
Area;
One of the 2 km stretches of coastline will be inside the MPA and the other 2 km stretch will be about 17 km to the west, outside the MPA, just west of Gerickes Point. The two areas were selected due to similarity in habitat, i.e. sandy beaches interspersed by exposed areas of aeolianite rock platforms, with subtidal reefs interspersed by sandy patches leaving a mosaic of reef in the surf zone. The reefs, and to a lesser extent, the beaches, are uncovered and recovered with sand due to wind and wave forces.
A trained team of volunteer anglers will annually undertake eight, 2 day angling outings to Goukamma MPA and the adjacent area west of Gerickes Point. This is one, two day outing every month and a half which will take place over a weekend. These dates will be set in advance, and cannot be changed, regardless of weather or any other circumstance. See Appendix 1. If sufficient data, i.e. catches, is not gathered during the first year, the amount of outings may need to be increased, or may be decreased.
During each of the eight trips the fishing will be conducted by eight anglers in the two 2 km chosen areas. These 2 km areas will be marked off at 100 m intervals with numbered poles, placed with the aid of a GPS. Four anglers will fish in one area and 4 in the other on the first day, and the teams will swap areas for the second day (pers. comm. Mann). The team of anglers will be kept the same as much as possible, but may have to be supplemented from a longer list of trained anglers depending on angler availability (pers. comm. Mann). No angler swops may occur on a specific trip. Experienced anglers and taggers (Appendix 3) will mostly be used in the project, but from time-to-time new taggers will be brought in for training.
All anglers will use standardised rock and surf gear and barbless hooks only (Mann pers. comm.). This can be achieved by flattening the barbs on barbed hooks with a pliers. The use of circle hooks is encouraged, but they are not successful for certain species (Mann, pers. comm.). All fish caught are promptly covered with a wet cloth, measured on specially designed fish-tagging stretchers and returned to the water as fast as possible with as little harm done as possible. Priority species greater than 30 cm total length will be tagged with plastic dart tags provided by the Oceanographic Research Institute (ORI). Galjoen may be tagged from greater than 25 cm total length. See Appendix 2 for a list of the expected priority species.
Measurements taken of the fish must be correct to the nearest millimeter (mm). All fish are measured to fork length (FL), except Kob, Belman and Yellow-belly Rockcod which are measured to total length (TL). Sharks which have a forked tail are measured from the nose to the point where the tail meets the body. This is called pre-caudal length (PCL). Sharks which do not have a forked tail are measured at TL. Rays and skates are measured to the widest point of their “wing-span”, known as disc width (DW).
The catch and effort data and tagging information will be recorded by each individual angler on site on a daily basis. Thereafter it will be entered onto a computer database for later analysis. Daily information which is necessary for anglers to record is angler name, team, date, start time and end time. When a fish is caught the following info is recorded: species, fork length, hook size and type, time of catch and beach (locality) code. Lost tackle is also recorded, as well as daily wind speed and Two 4x4 vehicles will be used to drive the anglers into the reserve and adjacent area to the selected fishing sites. Anglers should be dropped off at one point and left for the day to walk through the sites, as this increases the chances of effort being spread throughout the site (Mann, pers. comm.).
Equal amounts of time will be spent fishing in the two study sites, enabling a direct comparison of fish catches between areas. Fishing effort will be spread across each of the two study sites. This will be achieved by setting certain rules. The first rule is that anglers may spend a maximum of two hours at one spot, after two hours they have to move to a new spot a minimum distance of 100 m away (Mann pers. comm.). There is also a minimum time of 15 minutes that an angler must remain on one spot before moving on. Each spot (a minimum of 100m from the next) may only be fished once per day.
At each site, each day, two of the four anglers will be devoted to targeting big fish, and the other two to small fish for the whole day (Swart & Spencer pers. comm.). Big fish anglers will be issued with 1 kg Sardines and 1 large chokka per day. Big fish anglers may also bring their own Red Rock Crabs, Bloodworm and Octopus. Siffies may also be used in the future when we have secured a research permit to harvest them. Big fish anglers may use 5’0’’ hooks or 8’0’’ hooks for sharks. Small fish anglers will be issued I kg Red Bait and 20 White Mussels. Small fish anglers may also bring their own Bloodworm and Wonderworm. Small fish anglers may use 1’0’’ hooks only. No other hooks or bait may be brought with or used. Anglers may take as many rods as they wish for a day’s fishing, but they may only use one at a time, i.e. each angler may have only one line in the water at any time.
Psy
Goukamma MPA was proclaimed in the interest of protecting the inshore reef fish species, which are currently under great pressure nation-wide. Fish are the top predators in the surf-zone and by monitoring these top predators an indication of the biodiversity and ecosystem health of the surfzone and MPA can be obtained (Swart pers. Comm.). If the fish populations are doing well, it can be reasonably assumed that the underlying ecosystem as a whole, and the benthic habitat, is also doing well.
This proposed study aims to monitor fish diversity and abundance in, and adjacent to, Goukamma Marine Protected Area (MPA). See Figure 1. It is essential to ascertain whether the current MPA management strategy is having success or not. Monitoring the diversity and abundance of linefish can give us an idea of the state of the marine life.
The research question is whether angler catch-per-unit-effort (CPUE) in the MPA, which is currently closed to bait collecting and boat-based fishing, is increasing or decreasing over time, in comparison with the adjacent unrestricted area. In the instance that either of the areas are rezoned, the effects of this rezonation on the fish species can further be monitored through change in CPUE. Research by Goetz (2007) and Chalmers (2009) has suggested a closure of the MPA to line fishing, along with a realignment of the MPA boundary.
Objectives
• To compare and monitor surf zone linefish species, their size composition and catch per unit effort (CPUE) within the Goukamma MPA with that of the adjacent unrestricted harvesting area to the west.
• In the instance of rezonation, to monitor if there is recovery of surf zone fish species over time.
• To investigate movement patterns of key shore-angling species on a fine spatial scale (100m).To study the dynamics and estimate population density of resident inshore species using tag, release and recapture techniques.
SPARRABOS
was laas winter baie opgesand.waar gewoonlik klip was het jy op skoon sand geloop.gelukkig het ryno my laat weet .hele klomp ouens het met george derby geblank daai kant.ek het van die manne laat weet hys opgesand maar sekere ouens weet mos altyd beter dan blameer hul mombakkies op toegesand!en net vorige dag is dit vir hulle gese.;)dankie ryno jy vis ook so baie daar ken plek toe oe.hoop die winter spoel hy behoorlik oop vir daai bulle met die reselvet op hul ribbes.dan gaan ons hom aandurf.
Stefan001
Daai rooi aas was so goed niemand wou langs my staan nie. Sommer twee grunter daarop gevang.
Die tou leer wat hulle by die duin opgesit het maak die klim baie beter
SPARRABOS
bietjie oesterbanke staaltjies met ouens deel.dis nou maar bietjie interesante hengeluitstappies wat ons gehad het.ek en my maats het so met vroeer jare se george derbys maar op buffels gebly.vriend van my se ma het huis op buffels.dit was ons groep se saamtrekplek vir naweek.ook port luana op sedgefield by oorlede tannie annatjie.ons het maar net van goukamma mond gestap.omdat rivier soms oop was moes ons menige wintersoggend soms in gietende reen kaalgat deur ysige rivier.dis nie f.kken snaaks nie!!!!glo my. omdat ons ook maar bevriend geraak het met van die rangers oor die jare het van die manne ook tot ons redding gekom.wie ken pont oor goukamma.dan met pind oor wag daar aan anderkant van rivier landcruiser.ja lift agter op.dis cheat!spaar lang loop na oesterbanke sandlangs.vis ekstra uur langer want vamiddag is dit weer lift terug.en jaques sit en drink hande viervoet oldbrown sherry oppad terug.ja goeie ou dae.dan grootste skrik ooit.vroeg oggend pik swart donker deur rivier.halfpad na oesterbanke in pikdonker gaan sit connie op stomp om te rus.daai was toe nie stomp nie maar f.kken seeleeu walrus seeolifant dierasie wat daai tyd daar gestrand het.ja na daai geluid van daai seeleeu wil ek nie vertel wat connie gemaak het nie.maar ons het maande daarna nog gelag.ook die dag toe ek my aasemmer aspris gelos het en ons van agter sandsteenrots die ou dopgehou het wat emmertjie gevind het.daai gesig wat hy getrek het toe hy deksel afhaal ;)dan die visse.heelwat pryswenner gallies,enorme beenbekke,knopkop hotties. ::slr::
Psy
All fish in 40 minutes, tagged released.... fresh!!
Great time on the beach, water played the game till lowest tide.
Overall tagging results were fruitful.
