Theoretically, if you spool a strong enough line on the reel and pull hard enough, the drag will slip at some point, no matter how tight you turn the drag.
I said theoretically, since this depends on the quality of the drag. By Quality, I mean the "predictability" of the drag system.
Most drags are pretty predictable and smooth at low resistance settings, and then start to act funny the tighter you go. The cheaper drag systems lock up at tight settings and then slip in great big jumps (Or the line will simply break), not ideal.
Typically, the more you pay for the reel, the smoother the line will come of it at tight drag settings.
Be careful when conducting garage tests at tight drag settings, it's easy to bend the main shaft on which the spool runs (In a Grinder, the angle of the force pulling the line off the spool is perpendicular to the line of the shaft)
