Coffee grinder advise
Craigis
Hi there,
New to saltwater, been freshing it for many moons.
Was wanting to buy a reel for fishing off the boat and was looking at the Penn Accord 4000 or the Slade 4000. Will be fishing max 1 nautical mile off or in the bay.
I have a Torium 30 and SL30 for trolling and need a nice little reel for bottom fishing.
surfaMIKE
if you want a reel for bottom fishing then use a kp (scarbrough). 6.5inch kp with 30-40lb line matched to a 6ft fibreglass rod in the 10-16kg range should be fine for all your bottom fishing needs. Can catch anything from pinkies to big rock cod with that setup
andrev
Penn Accord 4000 or the Slade 4000????
if you feel right with this reel/s , buy it.....
accord the nicer one......i like it alot!!!!!
The Penn Accord 4000 Fishing Reel has been custom built with the braid specialist in mind. The Penn Accord fishing reels feature 4 stainless steel ball bearings plus infinite anti reverse, lightweight graphite body shape, aluminium spool with double ported holes and a sealed, high performance waterproof drag system. The drag surface area is large for reels of this size, offering silky smooth performance under the hottest of runs. The Accord spools are large and V-shaped with 0 degree taper for longer casts and better line control.
The Penn Accord 4000 Model Fishing Reel has a line capacity of 220yds of 12lb Fishing line and a gear ratio of 5.0:1
what else do you need.....noting dude-keep to it
