Chumming
Baasbez
Hi all
I was wondering, when fishing freshwater one try and make a "VOERPLEK" by getting as much mielie-bom in a certain place as possible to atract fish!
I saw the oaks on boats even chumming deepsea.
I thougt about mincing sardines,Prawns and maybe Squid in a meat mincer, make like Golf-ball sized balls and freeze them. When you get to your fishing spot, throw them 1 by 1 as deep as you can by hand or where you plan to fish.
Would this work, or would it be a waste of time and money?
swarley81
It would definitely work! There are some threads about this already, but if I'm not mistaken Neilg described more or less the same method, only his chum balls were tennis ball size :)
swarley81
Baasbez
Hammertime wrote:
The chumming technique.
Remember if it’s frozen it floats and that is a major *** up.
Hi
I gues that freezing my chum-balls is not going to work the way i thought it would.
Could someone please give the shortcut that Swarley refers to of Neilg, the chum-balls.
Please!:sf:::
swarley81
http://www.sealine.co.za/view_topic.php?id=10463&forum_id=25&highlight=tennis
There you go, I knew I've read something about chum and tennis balls somewhere... Post #33
Baasbez
Thanks Swarley!
What I've also done, I cut pilchards and anything fishy that I can get my hands on into very small pieces, compress it into a round shape and then put all of it in a plastic bag and freeze it - little bigger than a tennis ball. When I go fishing I take 2 with, take it out the plastic and throw it where I intend casting, as it rolls around the bits start breaking off, and in no time lots of fish around.
The freeze it part is of some concern as Neilg says to freeze it and Hammertime says that it musnt be frozen, otherwise it will float.:?:?
circa 64
Might be an idea to freeze it with a small stone/pebble in the middle to add weight, would also make your chum go further.
Pslatarix
What ive done and has worked for me is make what I call a chumsickle. What I do is chop up a 5kg of sards into 3mm slivers, up to 1cm thick. Mix in a whole bottle of anchovie oil and sometimes add a sarda or bonnie. Then I take a barrel sinker of about 1oz and tie it sideways so it makes a T shape with the line. I use 1mm line or the thickes I can get through it. I then put the mix into a 2l coke bottle with the top cut off and susspend the sinker about 2/3 of the way to the bottom and tie the line to a pencil so the lead stays where I want it to leaving a tag end of about 15cm. Then into the deep freaze. When its fishing time I tie a swivel to the tag end and drop it over the side. Oh forgot to mention that I cut the frozen chum out of the coke bottle. Then when its defrosted completely just pull up and clip your next chumsickle. You can also tie an onion bag around it for a slower release.
Pslatarix
Baasbez
Thanks.
Another idea i think of is to use MIEIE-BOM and mix the minced Sardines and Prawns into it, and then make the mixture into Tennis ball sized chum-bombs which i think would be fairly easy to throw without it being frozen.
Pslatarix
My thing is we like to make a chum line. Ie a consistant trail of bait. Just throwing them in loose, they could get washed away with the currents, nabbed by kreef etc.
Baasbez
I here you, but if i had 30 chum-boms i can trow 5 every 30min. So i should have a chum line for 3hours.
BulkCarrier
Nice trick I have heard of and might steal.
Throw all the guts and leftovers you have into a bottle when cleaning the fish at home. Freeze it and take it with you to sea.
At sea stab it a few times with a knife or cut a few holes and then drop it on a line with a sinker over the side. Chum in a bottle that defrost and only releases a bit at a time. From what I heard it work wonders for hotties because you can then start lifting the bottle and bring the school of hotties to under the boat.
Don't see why it won't work doing the same with pilchards and other bait. Can even make you own recipe with oils and juices you have left over from cleaning fish/bait.
Baasbez
Thanks BulkCarrier!
The problem is that i will be fishing from the Surf, and unfortunatrly not from a boat.
subaruseun
Thanks BulkCarrier!
off the surf or rocks use a mielie sak, mitsak or hessian bag filled with frozen bitz either bury bag at low tide and cover with rocks or tie to rope and sandspike or leave in the water and retrieve as the tide comes in ( grey suited men will try to steal your bag)
it definitely works
Baasbez
Thanks Subaruseun.
I will try a few of the methods and see which one works, although all of them might work, only on different surcumestances, no one knows?
subaruseun
also ice pellets works (cubes of frozen chum), you will need a catapult to get effective distance... more effort = more reward!
