Changing hooks on lures
mr zipozn
Howzit is it ok to change the treble's to single hooks on small lures xrap10 will it mess the action up? those small treble's are a nightmare to remove from shad
Tommo
Hi Mr Z, you can change them to singles. What you should do is use two split rings in a row, so that the hook rides upright instead of sideways. Have the one on the belly riding hook point down and the one on the tail riding hook point up. For shad you can usually just use a single on the tail and leave the belly ring empty as well, the lure wiull still swim fine.
Tommo
I would say a 1/0 or 2/0 short shank, wide gap hook, such as Mustad Big Gun. You may want to use your pliers to tweak the hook point in line with the shank, in order to keep the lure swimming staright.
mr zipozn
cool thanks again
