Casting
clont75
Mangi wrote:
Let us know how the casting went.  Get your other half to take a vid while you casting.  You might just see yourself doing something wrong, and that will give you the knowledge to what you can work on.  If all else fails, post the vid here and we guys can try and help.
I have to go do some casting practise myself after the galjoen season.  My "long distance casting" is a bit rusty.  Last one I tried my reel went ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ, boef!  Kraaines!  Ah well, what you gonna do?
lol, Hey Mangi,
you just came up with a brilliant idea, i just bought myself a camcorder and for the life of me never thought to use it when learning how to cast. "BRILLIANT MANGI" As soon as this shitty weather subsides then ill get out there although i still wanna buy that DAIWA Reel, but ill start of with the Okuma for now.
Mangi
Go for it with the Okuma, your technique is what is most important. If you got your swing right you can cast any reel!
Remember: Start slow, end fast. This will load your rod to its full potential.
clont75
hey Mussel Cracker, thanks for the invite, will definetely make a turn. first things first...where is leeukop, lol, sorry but i am going to need some directions. ill be coming from the westrand. very lekka of you to invite me. what does everyone get up to at the social?
Mangi
:fishn:fishn:beer:beer:beer:beer::slo::slo::slo::slo:clow:clow:hyst::hyst::hyst::ifishin:ifishin:puke:puke
Or something like that.
clont75
lol, thanks mangi, can always count on you to put things into perspective. only need directions now.
andier
The Thumb is only used to apply a little pressure on the spool so that it prevents a tangle. You would need use a band aid plaster in the inception once you are ok with this style remove the plaster.
Note that once the sinker hits the water there should be some slowing down of the spool your thumb can also act as a brake to prevent an overwind.
I find if you cover your thumb with a plaster you loose the feel..
willem wikkel spies
Guys;
friction causes heat.
heat and fishing line does not blend.
you should use the brim of the spool and nothing else.
yes it is difficult at first, thats why one should wet the line and your hand just before casting so that if you need to go from the line to the brim of the spool, theres no heat.
andier
do not over fill the spool you can also slow the spool down by placing your thumb on the side of the spool. Try using a bandaid plaster it will also help espicially if you have a fast spool.
