Casting with a baitcaster- how difficult can it be ?
Pisces
Hello everyone
I recently purchased a 6b Loomis baitcaster, not used to this type of reel I got overwind after overwind .
Is there a secret / technique or a "  rule of thumb " in regard to weight, line that you use drag settings etc.
Osie
Have a look at this post it helped me allot:
http://www.sealine.co.za/view_topic.php?id=23617&forum_id=32&highlight=baitcaster
cranky
the trick is to the settings...when you start off just open all the brakes and as you get use to it close the brakes you wont be able to cast far but you will get a lot less overwinds...set the spool tensioner correctly...just so that the lure drops slowly...and when starting off just gently thumb the spool to get use to it...its like riding a bike practise makes perfect...put buckets in the garden and practise pitching to them.
i have been fishing with a baitcaster for a couple years and still get overwinds (expect on the calais dc) the wind is a big factor...casting with the wind...easy stuff...against thats where your problems begin.
Q-bass
Cranky
Don't you mean close all the brakes first and then open them a bit more as you get used to it?
Pisces
First some bad news: I bought one of those Loomis & Franklin reels a while ago and found they are not the best in the brakes department.
First I had to exchange the reel because I could not set the tension brake at all. So test this way, with a fairly heavy lure like a large crank, see if you can stop the lure from dropping down by turning up the tension. If not, go return it. In the shop you can test your replacement reel like this, if the tension is turn up, the spool shouldn't move from side to side and if you spin it with your finger, it should stop pretty quick.
Second, I had an extremly tough time using fluro carbon line on this reel. With every change in lure (size) I had to forever tweak both brakes. I ended up with a magnetic setting of 9! OK, turns out the line I was using is just crap (not cheap, just didn't suit my style) and I replaced it with braid. But still, I have the same 'crap' line on other reels but didn't nearly struggle as much.
I would recommend replacing the reel if you can and get something else in the same class (Shimano Crestfire comes to mind: best beginners reel IMHO and it will outlast many others. I still use mine for heavy work after 2 years).
If you can't get a replacement, all is not lost. Get a thicker mono as suggested and also keep the magnetic brake setting a bit higher than recommended here.
Other tips I can add: Get use to feel the spool spin under your thumb as you cast. Always be ready to stop the spool at any moment with your thumb, for instance when you short cast and the lure is going to hit the water in front of you (the spool is going to continue turning).
Later as you get the feeling, you are going to be able to feather the spool with your thumb to make that perfect cast. Then you'll know why people use baitcasters :)
cranky
Q i call it opening out...but whatever you understand...just make sure the brake restricts the spool while casting.
another thing to remeber never overfill the spool...rather just below the line or less.
put cheap line to start with...it might save you money.
Osie
Pisces wrote:
Osie
Thanx a lot I guess patience and practice are the keys to success. No quick fixes!
Update your blocation and maybe myself, you and some of the okes that knows the bass fshing scene can hook up some time and they can learn us.
I am also very new to bass fishing and the only way I have been practising my casting is in my backyard one afternoon after the other and YES patience is the key word
