Casting Techniques - Coffeegrinder
Avash
Hi Guys,
What is the best way to throw with a coffee grinder to get maximum distance? I generally pull the line back from the reel spool 90 degrees to the rod handle forming a kinda trigger, leaving about 1 metre line from tip eye to sinker and then when i throw i kinda do it over head to get it going straight. Is this a good technique? Cos in my opinion it seems to put alot of strain on the rod tip
Thanks in advance
Avash
200ts
Hi, Yes you can use a leader with a coffie grinder.  Im not sure about the best method to cast one though, i use a straight overhead cast with a coffie grinder, and i get good enuff distance.
Raphi
Seeing as we're talking about coffee-grinders & casting with 'em...
I just thought of an untested method of preventing the line from getting tangled. & I need some opinions on this thought;^^..
When casting in wind, especially... Can one cast but without turning the wire-thingy over? But, instead, just letting the drag really loose... Will it OR won't it mess up the drag (Wear it out quickly)??
Thanks in advance...
Raphi.E
200ts
Hi Raphi, I have tried that believe it or not, and landed up with some impressive bird's nests,  i think the best way to prevent tangles while casting is to make sure your reel is not overfilled with line.
surfaMIKE
Yup, I use a leader with my R&S coffee grinder, and have the leader wrap around the spool 3-4 times. I can get better distance with my coffee grinder than with my multiplier
Your method is fine, thats what I do when I cast with my grinders, but when Im surf fishing, I take the line with my left index and middle fingers because the rod butt is short and hold the grip above the reel with my right hand. With my light tackle setup I hold the line with my right index finger and hold the grip below the reel with my left hand because the rod butt is longer
HEIHACHI
great! thanks for that 200ts!
i guess it depends on the size of the rod as well? like with my dropshot i whip from the side and it goes miles bu with a 12 foot it goes overhead.
surfaMIKE
Raphi.E
Cant you do that with a baitrunner? But then you have to brake the spool....
deisel
you throw the same why as with a multiplier, use the rods ability to flex to maximize your distance,... my lady throws 95 metrs with a bg60 and a 12foot exage
Excellent advice Toots...!
Heihachi... you should always fish with a leader, regardless of the reel used...
wp34
Hi guys!! Look at getting a Bionic Finger(BF)!!!!! Barry Wareham has them for about R100 I Did some experimenting with my grinders and find that if you use a BF in the "reel down" position(like a multiplier) you get better distance than fishing "reel up". Casting overhead is def the "better" way of throwing a grinder I get way more distance and direction overhead!! I use an Assasin Spin rod with my Assasin lite HMG butt section and get about 150 m with 5ounce and bait(small bait chokka or small mullet head) and .35mm nylon with .60mm leader
Marthin
balance is even more important with a grinder/rod than a multiplier/rod. If you have the correct balanced setup from sinker to rod butt, you will come very close to most guys with a multi.
I would suggest, a: You use a sligtly softer rod than usual. b: Your rod has a bit longer butt section than the usual sea rods. c: You can load your body better if you turn ur body slighly around and then come around ur body in stead of over.
Like Shoaib Achtar from Pakistan who bowls faster than the rest cause he swings his arm around in stead of bringing it over.
But it takes som practise to not cast over 3 guys next to u.
Avash
Thanks for all the input guys, will give it a shot and see how i get along, Marthin you mentioned balance and i don't expect you to know exactly which rod i am speaking of but i am getting a Shad Pro stick of 11 Ft and a BG60 Daiwa any ideas if the will be a balanced setup? The rod and reel do feel good together obviously aside from the intro of bait and sinker.
Regards,
Avash
