Hi Guys,
Which would you say is a best casting reel to match a 14ft rod. Hoping to get more distance.
What do you think about the GW40.
On clean beaches we normally use anywhere between 15lbs and 18lbs running line with 80lbs shock with grip leads/grapnel as you say form 150g/5 1/2oz ,175g/6 1/4oz or 200g /7oz, but in rock we use 25lbs upto 35lbs running line with shockleader with plain leads mainly 6oz to 7oz some use 35lbs straight threw as they are not casting far into gulleys for cod,Thanks Tope, I'll be chewing on this for a while.
It has me a bit worried for our own environment for a few reasons:
1/ We normally fish with grapnel sinkers and pulling a 6, 7 or 8 ounce out of the sand on 20lbs line ???
2/ As you say, If you can get a bait to 160 / 180m, your chances of a pickup on a small to medium size monster fish / shark is very good, needing some 300m+ of backing just to get into the fight.
Cheers and thanks for the feedback.
