to add to this tread further:
its one thing placing your hooks in the bait.
its another thing, casting the bait with these hooks placed in the bait.
one needs to know that when a cast is made that you do not cast with a ripping action, a smooth action is preferred, other wise you could rip the hooks from the bait.
another aspect is, where do you cast the bait fish "livie"
that is the most important aspect is the placing of the baitfish.
obviously when the baitfish is hooked like cobia drew the picture, then that live bait needs to be in calm water.
if it was in a stream like environment then the bait fish will be facing down stream the whole time and will die quickly.
placing the carrier hook in the mouth area would keep the live bait alive for longer. the question is, where you have placed the bait fish, is it looking natural in the water to the hunting game fish?
so obviously you need to know, how to read the water and to know where the water would be best suited to present your live bait.
so when placing the carrier hook in the bait fish mouth, could hinder a Garrick from swallowing the baitfish as the hook is in its way.
returning to the aspect of swallowing the baitfish:
my experience is that Garrick will swallow head down first.
salmon, caught on live bait slided rigs were all swallowed from the tail "contradicting cobia post"
kingfish, they tend to smash bait so hard that nothing is left afterwards.
i have slided many baits and have caught my fare share of edible fish.
i have had many a time, small puncture wounds in shad, indicating smaller salmon did try the bait but left it alone.
even when Garrick drop your bait you will see when a Garrick had a try at it.
but kingfish, I once slided a dead shad at st lucia.
after having no pulls, or so i thought, i reeled in the shad. i inspected the shad and found that it was like the shad was hit with a 14lb hammer.
ie: crushed, the skin on the back was ripped open and the flesh was squished out. so it was burst open.
i could only conclude that a kingie came along and had a go, but missed it.
they don't worry about size etc. smashing it is the way to do business.
the other aspect is, smaller fish will try and swallow a big bait and might drop the bait.
years back we had the "chomp advert" where the small hippo tried biting the chomp and dad came along and just swallowed the chomp whole.
that is the same with your bigger fish.
they don't worry about going down head first, its in and gone and they move on.
so it is a fact that the smaller bait fish will be casted further and might be taken before the bigger bait fish.
the down side of casting a smaller baitfish, is that the vibrations set off by the smaller fish is much less then a bigger bait fish.
all game fish have the lateral line which will assist them in finding food.
so it might be a good thing to cast a bigger bait fish at night...........
the other down side to casting your bait fish is, that the bait fish is in a small area.
the bait fish could also die much quicker.
this is where sliding is better.
it does get your bait fish out in the right area, if to far to cast. the stress on the sliding is much less then a violent cast.
the bait fish now swims to the suspected feeding ground and is longer in the strike zone if needed.
although a bit off topic when sliding a baitfish i normally just assist it just past the first big wave, from there it should swim further and can be seen as a baitfish being swept away from the beech side by a rip current. this could prompt the game fish to attack.
also take note of where you cast your bait fish and when you get the pulls. that is the right area that you will quickly learn over time.
the last aspect is that if you cast a live bait, the best thing would be to stand with rod in hand.
you need to give freespool immediately after the pick-up.
on sliding you may use a pension pipe.
just one last very important aspect.
the best feeling ever is when standing with rod in hand. then sometime the baitfish becomes jerking and then the pull comes.
the pull "pick-up" of the bait fish is the best feeling ever to have on a casted live baitfish. much better then the fight.
so do try and stand with rod in hand.
daars min dinge wat n beter adrienalien rush kan gee as daai trek.
happy fishing and tight lines.
Stadig nou Willem, praat ons nog van "Casting Live Bait"?
Admin "K"
