Casting Braid vs Mono
Koper
OK
So I'm acquiring a new shimi 15/30 for to be used mainly for galjoen fishing.  Had my mind pretty set on loading it with casting braid, until some member throws a spanner in my works.
So here is my question.  Is it worth the money, is the "feel" so much better, etc.?
I've read from a lot of members that used mono & then proceed to using braid.  I wanna hear your thoughts, pro's, cons & recommendations.
Keep in mind I've never used braid before.
Thanx Guys
Simen
Koper wrote:
OK
Thanx Guys
Koper, dont think twice, get the braid you will never be sorry, I guarantee you. There is nothing better for scratching and close fishing on the market.
HOWEVER:
There are some factors you have to consider.
The major mistake most guys make from switching from mono to braid is line diameter.
DONT switch from say 25lbs mono to 25lbs braid, its a recipe for disaster as the braid will break cast after cast. There is no body in the braid to absorb heat or allow a b it of stretch
If you were using .35mm mono GET .35 BRAID.
Also buy the right braid
See:
http://www.sealine.co.za/view_topic.php?id=20911&forum_id=1&highlight=Braid+vs+Mono
post 21
Koper, ek gebruik 80lbs 0.46mm casting braid op my 15/30 vir die gallies....as hulle hang is dit vas pappa!!! Wees maar versigtig, jy mag dalk 'n vinger verloor as jy nie versigtig is nie....eina!!!
...of soos hulle sê..."as jy dom is moet jy maar voel....lol"
:doh:doh:doh
old salt
interesting reading especially the finger section must be finger foods or something.............n'e Koper
go the yellow xx 042.mm way and smile with peace of mind and fingers ....casting with confidence is the most important thing next to technique and if you need to worry about fingers you wil not be able to reach the goals you set out for yourself.
my view others may differ all good each to what he feels most comfortable with i prefer normal co -polymer for this reason and for whn fish decided to turn infront trhe strect in mono then does assist in retaining the fish as well. tx
Fanie
Lekkerste braid is spider wire, en ek het nou-die-dag nog een gesien wat ek baie van hou. Hoe meer snotty hy voel hoe beter.
Dis soos Simen se, as jy eers een maal daarmee gevang het is jy 'hooked'. As jy kap dan sit die hoek. As jy die kunsasie trek en die vis mik-mik net so om te hap dan weet jy reeds hy's daar. Ok ek hengel met stywe stokke so jy voel alles wat daar gebeur - nie dat dit altyd sin maak nie.
Altyd sag en geen gehue nie. Dis heerlike lyn om te gebruik. Geweldig sterk, veral die 200lb :-D
Fanie
Askies ja ek wil net beaam wat Galjoen se. Die braid het nogal 'n lewendige 'saag' aksie, soos bv as jy so 'n lussie om jou vinger kry en die vis trek weg teen 160km/hr.
Meeste visse kan so vinnig wegtrek, 160km/hr onder 0.01 sekonde. Dis die waarheid, maar hulle doen dit net as jy 'n overwind het of die genoemde vinger storie. Ander tye trek hulle maar stadig weg ;-)
Scarbra
Koper,
I've been using braid now for about 2 years for rock & surf as well as boat angling and I have learnt allot. I now know that mono and braid have their own place in my tackle box.
As the guys have been explaining braid gives you unmatched sensitivity to the end of your line which allows you to make more hook ups. This I have found is important when scratch fishing or when using lures that are actively being fished like plastics etc. The drawback of braid is that it is very susceptible to how it is being handle and I have on more than one occasion cursed the stuff when setting the hook only to have it part for no reason at all. I have found that changing from mono to braid required a change in attitude that initially was difficult but now it’s easy.
Firstly, putting braid on a fishing reel is very important. Initially it needs to be wound on very tightly otherwise it cuts into the rest of the line on the drum. I usually first wind the braid onto a spare reel and then wind the line onto my reel while the drag on the spare reel is set as hard as I can reel in. This is an important step to enjoying braid.
The next important step is to attach a leader to the front end of the braid. I have tried several knots and have finally found one the works. The lesson learnt here is that my normal mono knots were unforgiving and parted several times before they worked. I don’t know the name of the knot off hand but essentially a loop is formed on the mono leader and the braid goes through the loop and wrapped around the mono many (the more the better) and then fed back in through the loop. Pull everything tightly in an organize fashion and you are set to go. I try to keep my leaders shorter than longer because I feel the stretch in the mono leader defeats the purpose of the braid but then sometimes you want a longer leader for rocks etc. so it’s up to you.
The way you handle braid is the most important part of my advice to you. If you are not willing to treat braid with respect you are going to hate the stuff. Braid does not like any kind of abrasive action. For example it’s difficult to cut braid with a pair of scissors but use a blade it parts like silk. Overwinds have to be managed with care and the moment the braid goes into the side of the reel drum it game over. Also dealing with an overwind on the rocks is trouble waiting to happen. Reel in your line and go stand in a clear space and deal with your overwind. I have learn’t the hard and expensive way that you don’t give the reel with braid to a friend to use either. It always ends up in line being lost.
I also agree with the guys about the line thickness. Match the line diameter and not the kg.
Braid also requires a change in the way you handle fish. The initial burst a fish gives when hooked has parted many of my lines. Mono is very forgiving in this area. I have noticed that I have to keep my wits about me when setting the hook because I was used to mono and now with braid there is no stretch in the line so the strike force goes straight to the hook. This is usually the most difficult when the rod is left unattended.
The part that I don’t like is that the colour of the braid on the front starts to fade and this makes me wonder about its strength.
It summary braid is fantastic if you are careful but if you are not interested in the fuss stick with mono.
tintin1
I've tried braid and mono and agree with all that has been said here about the diameter issue and needing to take care with the braid.
I also agree that it is great for scratching.  Fumbling bites on mono become hookups on braid and the difference is easily 2 to 3 times the fish landed on braid.  But we do not always want the small stuff so I wonder whether it would be better to let the little stuff have a feed and go away (mono) or pull them out, talk sternly to them and return to the sea???
I am confident that mono picks up most, if not all, the decent fish that find your bait.
One thing has not come out in this discussion yet is that when casting spoons and plugs the braid can be a problem because the lure is a lot more aerodynamic than a sinker and bait.  It flicks around, especially in a cross-wind.  Then you had better have that thicker braid and a well-tuned thumb or you throw off the lure.
FWIW - 0.3mm braid is too thin for me on a Saltist 30.  99/100 casts are perfect.  But then - a loose loop and snap.  Usually just when I'm thinking I'm in the zone.....
