Casting and fishing with a Baitcaster
Herman Nel
As bigmouth says x1 rodlength is fine, for fishing using speedclips or Rapsnaps or so.
In the case for R-bend spinnerbaits you tie them to the line directly....if you change your lure say 5 times your leader will be too short....in other words when you cast , the knot that joins leader and mainline could be exposed and not "on the spool"...resulting in backlashes or even line breaking under the pressure of the cast!
Personally I dont like leaders that much as I feel the more knots between you and your catch,the higher the risk....I mostly use leaders on my light and ultralight outfits.
Greetings
Osie
I was thinking of only using monofilament line without a leader.
The reason for this is I read a few articles about flourocarbon and some okes says that if your knots is not done correctly it will break of easily.
I also wondered about the leader and the number of knots in the line.
If I am wrong please correct me Herman
Osie
Thank you I was struggling to choose if I have to buy mono or flouro but I gues mono would be better and cheaper to start with.
Bigmouth
Hi Osie
Probeer Awa Shima se mono, excellent value for money.
I think they go for about R70 for 500mtrs.
Very very strong and nice thin diameter.
plugger
I've been Bass fishing for about 40 years and have never used a leader yet. Keep it simple. Don't use snap swivels and only use a swivel on a Carolina rig.
Herman Nel
Plugger
Why would you suggest not using snap swivels? Are you referring to swivels itself or snaps?
I use Rapalas' RAPSNAP, and a few other brands too, and personally I feel it is a must because, it gives a better action to crankbaits than normal knots to a split ring ( or a very complex Rapala knot done wrong) and in a competition I will be able to make at least 2 casts in the same time it takes one to tie a "proper" Rapala knot.
Also, how would you do a Twin Fluke rig without swivels?
Also,certain conditions ( eg tightly packed branches, or rocks covered in freshwater mussels ) require leaders ( mono for eg ) up to 50lbs in certain cases, can you cast 50lb mono 20 -30 metres?
This is not an attack on you,please dont get me wrong. Your opinion on this matter is repected, but this is my opinion.
Herman
plugger
Hey no offence taken. I have lost fish on snap swivels (quality ?) and don't like having the extra knots. To be honest i have never ried a Twin Fluke rig so maybe i can learn something here.For bass fishing I don't bother with a leader, if i'm fishing timber I'll use a reel with heavier line. Just my 2c worth.
Guys
It seems we've got a nice topic going here, the current line of posts anyway, now here's my take or understanding: Leader's, i don't use them, i opt for the thicker line aswell when needed (timber fishing), snaps not snap-swivels I use with all my hardbaits and have not lost a fish on them yet biggest was my PB a 4,02 minibus called Dorothy.  Now monofilament? I only use that for topwater lure's as it doesn't sink as quick as fluro does and I refuse to use braid ever! (I tried all makes and kinds and just can't get a liking in it no matter what)
