What will be the effect on (eg. Torium 30) reel be if the Carbontex washers has a thickness of 0.5mm ( or 0.8mm) and you replace them with 1mm Carbontex washers.
e.g. If there are 3 washers of 0.5mm between the other washers the current total thickness of the Carbontex washer is = 1.5mm
Once they are replaced it would be 3 washers of 1mm the total thickness would now be = 3mm between the other washers
1. What would be a major concern?
2. Can you only use 2 x 1mm washers and where would you place them?
3. Any thoughts \ suggestions?
', 'images/emoticons/tightlines.gif')
