Canon 400D
Ulua
Canon 400D with Canon EFS 18-55m Lens Rubber protective cover 2x Batteries, 2x CF Card, Cleaning Kit, Bag Hardly used good condition. R2500
Extra lenses
1. Canon EF-S 17-85 f/4-5.6 IS USM Lens Image stabilizer Extra Hoya Polarised and UV filters Hardy used good condition. R3800
2. Canon Sigma Aspherical IF 28-300mm Lens UV Filter Hardly used good condition. R1800
Great for wide angle fish and landscape pics.
Ulua
I am not that clued up with camera and lens specs but this is what I pulled off the net re the Sigma lens.
(From Sigma lens literature) The Sigma 28-300mm f/3.5-6.3 DG Macro lens covers all the focal lengths from 28mm wide angle to 300mm telephoto with a 10.7:1 high zoom ratio as well as macro capability. It packs a lot of performance in a compact package with ultra compact dimensions (Diameter 74mm and Length of 86mm) that make this lens the ultimate traveling companion. It's the ideal lens all types of photography and optimized for digital SLR cameras.
The new multi layer lens coating and lens design reduce flare and ghost, which is a common problem with digital cameras and also creates an optimum color balance through the entire zoom range.
This lens features one Special Low Dispersion (SLD) glass element and one aspherical lens in the front lens group, and one SLD glass element and three aspherical lenses in the rear lens group. This lens provides excellent correction for all types of aberrations.
The 28-300mm f/3.5-6.3 DG Macro lens has a minimum focusing distance of 50cm at all focal lengths and is equipped with a macro mechanism for close-up photography at 300mm telephoto, allowing a maximum reproduction ratio of 1:3.
This design allows for stability and compactness in design as changes in focus are made in an internal lens grouping. This also gives the advantage of a non-rotating front lens assembly, which is of great benefit when using polarizing filter and Petal-type hood.
The 28-300mm f/3.5-6.3 DG Macro lens is equipped with a zoom lock to prevent the lens from creeping due to its own weight, and to offer protection while the lens is being carried.
