Buying or makeing your own Partical bait
What do you fined works the best
  • Partial
    Votes: 0 0.0%
  • Bom around the sinker
    Votes: 0 0.0%
  • Partial and bomb around sinker
    Votes: 0 0.0%
  • Feeding with spot rocket
    Votes: 0 0.0%
  • Total voters
    0
bapsfontein
Hi All
Was just wondering...how many of your guys make your own feed and how many buy....I fined if you make it yourself it work very good...I normally buy all the feed loose and mix it and keep it in a drum and prepare it when I go fishing....I bought some ones but it is to expensive....wonder what you do....
pumamangp
i make my own and when i feed i will drop the bait with an inflatable or if casting ill spod and use a pva bag
Flashback
Beslis beter om jou eie te maak dan kan jy ook verskillend maak vir verskillende venues!
Belangrik om die voorbereiding net reg te doen!!
Daar is baie plekke wat sade verkoop wat goedkoper is met baie van die goed!!
chris_leon
Buy all my seeds separate and make my own mix.
If fishing close in - usually the trusty spod and marker rod come out. But if more than 100 i use the good ole canoe....
MadCarper
I've always made my own. The 2 times I bought different makes of prepared particles it was a waste of time. SA bait companies need to get back to the drawing board on prepared particles with preservatives being sold in shops... Its also cheaper to buy raw and prepare your own.
JohannM
yes make your won and dont make it too complicated.
Hemp Tigernuts Maize
Maybe add: Maples, Bird seed, Chick Peas
I have not found that any of the 20 million other particles people use have made any difference really.
I have one venue where the fish really like chick peas, so I will add some chick peas to the HTM mix.
