Burnoffs or broken traces with fish-on
1309sg
Last weekend I lost a fish near the side when the leaderline parted (chaffed on something or other). The fish took off and started jumping like a tarpon, and this was quite a big fish, shaking it's head like crazy to get rid of the hook.
Does anybody know what happens to these fish, especially when there is line involved too and not just a hook that can possibly rust away?
1309sg
Lag maar Wayne, ons gaan sien wie lag die lekkerste die 30ste!! ::SNee, ek is ernstig man, wat word van die arme goed? Ek kan my half voorstel hoe die lyn saam met hull gaan en haak aan 'n klip of 'n bamboes......
Catch 22
Ek glo n paar visse bly seker maar in die slag maar n vis skud darem gou n hoek uit sy bek uit as daar nie tension op is nie.
Ek het al haaie gevang met twee hoeke in die bek ens. Ek glo n paar vrek maar die meeste raak ontslae van daai hoek.
misguide
Most hooks (not stainless) will rust away in a few (3-4 in my opinion) days. If the hooks rusts away then line goes with it.
If the line gets snagged on reef then there is a possibility of the fish drowning or being eaten by a predator.
This is why the use of barbless hooks (only for slides) was implemented by MCM for League fishing.
Wayne
::S.... Just 9 days to go and I,ll be home... should invite some more Sealiners to join us..the more the merry...LOL!!!
My thought on this is as the same as yours,with line hanging from a hook that is well stuck in the fishies mouth,and it gets caught on a babamboos kop,does this fish die? or does it survive in some strange and wonderful way as nature has showen us before? Be good to see what the experts have to say..like Trophy,Reefman and the rest...
1309sg
Agreed...perhaps one or two that can attach a slide without the bait moving TOWARDS the angler......^^..:fbash
Wayne
Are there any of the Sealine guys that would like to teach us the slidding thing on that weekend..as you can read...we are not the best sliders around...we throw sinker,attach slid with bait..and jig the rod...but the blerry thing keeps coming back towards me..now I ask you all with tears in my eye's...am I trying to catch the fish or is it the fish trying to catch me? :f1shy
1309sg
No takers it seems Wayne... but I guess I'll have to give you manna for taking the blame on my sliding technique?:clow
sdunlop
From tagging research up at vidal, many fish have had hooks not removed (i.e. swallowed etc.). The fish were still tagged and a note was made when hooks were not removed.Recaptured fish that originally were released with hooks in them have been caught numerous times. Interestingly some hooks have been found protruding from the anus. A small tug on the hook and it is is free.Most hooks that were pulled out have not even been badly rusted!! Note all kooks were barbless too!
khalaharikid
Guys sinker type is very important, you must make sure you use the right grapnel with heavy wire, there are a good few makes out there, seven ounce and upwards is a good start.
Throw the sinker and let it lie for a bit then test that it is nice and tight by pulling lightly, if on the beach try get the bait over the first set of waves, then dont shake when the foamies pull on the bait let them pass then go again till the bait is out
kk
1309sg
Thanx sdunlop. Having never even thought about barbless hooks, what is the success ratio with them on edibles / in-edibles (vs barbed hooks)? Should one then rather go for the circle hook than the J-hook?
1309sg
kk
Thanx kk. I've read about the sliding traces and will build some (thanx reefer) but what about the rest of the set-up? I use an exage 1468 with a Torium 30 with 300m braid backing (50lbs) and mono about 350 meters, 30lbs. This is my standard surf kit.
Would this be heavy enough, cos I don't really wanna reload the whole reel with stronger line if it's not necessary. Damn expensive anyway.
Wayne
KK..we will be trying that...tech you just said...
Sakkie,no mana needed boet,I suck as much as you do on sliding...ROFL!!! Yip and it looks like its going to be you,me,the Mrs and the rugrats on the beach....
As for the barbless hooks in all comps we fish barbless and somtimes even when I fish for fun I take off the barbs,or maybe just a habit of mine (that is a good one for a change..LOL!!!)
sdunlop
I fish only barbless hooks for edibles in vidal and else where. You loose some but you get some. I just feel better at the end o the day returning a fish, with barbless, the hook is out in a second!
Some of the senior guys can maybe comment on success rate. I have not had much luck with circle, besides off a boat. Need to persevere more I suppose.
khalaharikid
kk
The bait you slide should be relitive to the line and rod, 30lb is around 0.45 or 0.50mm so that should be fine, slide a makkie, or a chokka, dont try a big huge bait, use a nice streamlined bait will help getting it out faster and easier, nothing wrong with torium 30
1309sg
Sounds good kk, thanx for the help. If you think of any other essentials, let us know.. LOL, otherwise we're destined for sharkbait..LMAO:ssswim:
misguide
1309sg, I think your post was the right one to chat on regarding the issues we just discussed (and then hi-jacked poor Ants post)
i think it is a good thing that anglers at least thinking about what if and what happens etc....not like the old days of who cares...still plenty of fish in the sea.
khalaharikid
On the other post Arrie had a good point, 50% of slides get burnt off what happens to the fish????
Who has caught a fish with a slide trace in its mouth????, nobody that i know!!!!!!!
So evidence shows, that that fish will die, line tangles in rocks or wherever and the fish dies, that's the general consensus, sure it must happen, but every time?????, I don't know .
So in answer to the question what happens, the fish dies and you are responsible, that's the general consensus!!!!!!
It bad for the environment
So what is the solution, who can come up with some ideas???
