Budget Fisherman
Avash
Hi Guys,
Can anyone give me some advice on this combo:
1 x 11 foot Shad Pro Graphite (i think this was featured in the ESA Mag)
1 x Shimano Nexave 10000
Total Cost = R800
I think the price is good but do you think i could do better in that sort of budget?
I am only targetting edibles
Thanks and regards,
Avash
Avash
Sorry forgot to mention that i only know how to fish with coffee grinders
Thanks in advance,
Avash
neilg
What you want to target with it ? And where will you be using it ?
If "normal" edibles then it's good.
I have a 2500 Nexave reel (I think), and it has served me well.
don't know the rod though, if it is the Sensation rod then it's not a bad rod, I just think the quality of the flip up guide inner is on the "iffy" side, the rest of the guides are good for mono and braid. Rated about 2-3 oz, which makes it great for small to medium bait and spoons/plugs.
Ofcourse there are better equipment available, but it will also be more expensive.
Avash
Hey Neil,
Thank you for the prompt reply. Do you perhaps have something better that you could advise me on? Would be willing to up the rand value if it is proved to be in my best interest. I really don't want to end up being shanked if for couple hundred more i could get something better than the one i'm looking at
Regards,
Avash
neilg
Avash,
I will always believe a graphite rod is a graphite rod !
The Sensation is a nice rod, but you could get another rod for half the price, and it has the same rating. I'm very happy with my Loomis and Franklin 10ft, also a 2pc and also rated 2-3oz. But then I still think the Sensation has better guides for braid (except for the flip guide).
If you gonna go mono line then look at the L&F, if braid then look at the Sensation.
Remember both are fairly "light action" rods so they not meant to target the monsters of the sea. But if you have the patience and experience even bigger fish can be landed. It just takes more patience, a cool head and the right conditions. Put it this way, the Shimano Exage 10ft Spinning rod is rated up 200g (1ounce = about 28grams), now that rod is for pulling big fish and throwing heavy baits/lures, but then these rods cost in the R 1500 range each.
Reels, well it is actually very very difficult without knowing what you really want to target. I have this thing in my mind (which will always stick), if I'm buying spinning reels and it's under R 1000 (now 1300 with the new prices) I go for Daiwa and if it's over R 1300 I go for Shimano.
I don't think the Alivio is a bad reel, but there are better reels that's a little more expensive.
My question, why a 10 000 size reel ? Where will you be using it and what will you be targetting ?
I use a 8000 (same body size as 6000 but deeper spool) on my 12ft L&F rod, I have used the 12000 Spheros on it and it just feels too big for the rod. I believe a 10 000 on a 10ft rod will also feel too big and affect the balance of the rod.
Consider between a 5000 to 6000 size reel (or a 8000 if the 6 and 8000 have the same size bodies ) for the 10 ft rod.
Then also, where do you stay, the reason I ask is because I would like to know how often you would actually be using it. I noticed Witbank dam in your profile, if so then you gonna probably use it max 10 times a year at the sea, in that case even a cheaper reel could end up lasting you a lifetime.
What line will you be using ? Mono or braid ?
More for bait fishing or more for lure fishing ?
I say again, Nexave is not a bad reel, but for a few dollars more you could get a much better reel.
If I didn't know better I would have told you to look at the Shimano Sedona, but I'm not happy with mine, so I won't recommend it to you either, they go for about R 700. It really is a nice smooth reel, but SERIOUSLY lacks in the line lay department, it bunches the line at the top and the bottom (but leaves a 2-3mm gap between the top and the bottom of the spool).
A reel I will recommend is the Shimano Spheros, will last you very very very long if you look after it but will cost in the R 1000-1300 range.
Daiwa Oceano (small only a 4500) is also a very nice reel and also in the R 1300 range.
But I'm typing off without knowing your intentions.
Please tell me more
Avash
Hi Neil,
Well when i went to the shop the 10000 was the only reel that i felt was a good balance with the rod i mentioned, the weight distribution and everything felt perfect but i could be mistaken.
The line i will use is mono and in terms of bait i will be using the organic stuff, so no lures, probably sardine, mackerel, prawns and chokka
I live in JHB and the only time i will be fishing with the kit is when i go down to Durbs which would probably be about 12-15 times a year.
I will only be targetting edibles like, shad, grunter, blacktail that sort of thing
What do you think your recommendation would be in line with what i've told you? And can you give me a ballpark cash figure?
Regards,
Avash
Homie
Avash,
If you want, I would be glad to help if you want to learn how to cast a multiplier ! I only learnt this year, and its going great !
neilg
Okay, now I know what's up.
First of all, for some reason Shad Fisherman love to have BIG Grinders filled with LOTS of fairly heavy line, why well I just don't know, there is just no sport in catching a 1kg fish on 15-20kg line !
Shad can get a tad dirty at times, but they are on the move the whole time, the will not think twice to run between the rocks once hooked, ESPECIALLY in the very shallow water. The chances of a shad taking more than 50m of line is SLIM TO NONE, hell the chances of it taking 20m is actually quite small. Most of the shad caught are in the 1-1.5kg range, so they are not strong. If you were getting into 5kg and up elf then I would say go heavier and hold on.
If you have a reel that holds about 150m of 6-8kg line your a A for away ! Saying that, a 6000 -8000 size reel will definately hold more than enough line, actually a little too much. A 5000 size reel would be great.
I have never encountered a fish (the ones you mentioned) that have taken more than 50m of line off my reel (and I'm catching them on 3-4kg line using 2500-4000 size reels). Sorry had 1 grunter that took about 60-80m, but again, it's not that much line and I was using fairly light lines.
If you are targetting Shad, Grunter and Blacktail you want to go fairly light on terminal tackle aswell, sinkers in the 2oz range are perfect. With shad it's actually better to go driftbait with either a half pilchard or a full one, and that makes the lighter action rods PERFECT.
So in choosing a rod rated to cast 2-3oz you are making the perfect choice !
Again, based on what you want to target, you don't need a very expensive and strong reel, the Alivio is actually good enough, would still just say look at the smaller size.
Remember, you will be holding it in your hand, so it must suit you.
I have bought over 30 grinders so have quite a few, some of the earlier ones were "cheaper" reels (from the top brands), and altough they all still work I won't even dare to use (or try and compare) them when I have my hands on the Exceller ,the Spheros, the Stradic and soon the Oceano.
If you want a reel that will last you a very very long time look at either the oceano or the spheros, as said both in the R 1000 - R 1300 range, both REALLY MADE FOR SALTWATER, both have very good and smooth drag and both have enough capacity for what you intend using them for.
Personally I would go for the Alivio and the L&F rod if budget was really limited - R 800 like you said.
But if I had a few rands to spare it would be the L&F with either the Spheros or the Oceano. This setup would cost you in the R 1400-R1800 range.
And don't forget to get yourself a silver 1.5 oz spoon and a bronze 1.5oz spoon !
I would also say get yourself a purple Onda Onda but I know the changes of getting one at this stage is SLIM TO NONE.
Some advice on the Shad, rather use a long shank hook and about 500mm of 1mm CLEAR leader than using longer steel trace, I guarentee you you will get more fish (and won't lose many either). I prefer to use 2 hooks when I target them with bait.
And one more thing, the thinner your main line the longer distances you cast. Thinner diameter = less wind resistance = perfect for drift baits.
Need anything else lemme know
Avash
Neil,
Your time and effort in responding to me is greatly appreciated bud, you have no idea. Thank you so much for the tips and tricks and now i can make an educated decision when next at the tackle shops. Again thank you so much boet has really been a pleasure
Regards,
Avash
Avash
Homie,
Sounds like a plan thank you for the offer, will be sure to take u up on it, however for the immediate future think i will stick to grinders. i have been out of the game for so long that i think i will get my experience and confidence levels up first before venturing into the unknown
Regards,
Avash
Avash
Neil, Homie
There's a guy on the forum called "Khan" who seems to have had a few BG 60's for sale for R600 seems like a winner, have no idea about the reel what do you guys think? Have asked if he has anymore and awaiting his response
Regards,
Avash
Homie
Avash,
Im bot too clued up with the BG, I know Mike Pike has one and he swears by it. Uses it for spooning and plugging.
From what I think, it should be fine, just check the line capacity.
neilg
Always a pleasure helping a fellow fisherman
concerning the BG60, it is more than capable.
pls note - I HAVE NEVER OWNED ONE
but
From what I've heard it's like a TANK, bulletproof and just as hard, but good.
I consider it like comparing a Citi Golf to a new Golf 5 (or is there a 6 now), Citi Golf still does the job, but the Golf 5 is just so much better ...
Avash
Awesome Guys,
Thanks a mill, have made contact with him just waiting to hear the verdict
Regards,
Avash
surfaMIKE
Wow. Great advice there nielg and Homie
We have three Daiwa BG's. A 13, 20, and 30. Great reels, honestly awesome, I just wish we looked after them better, but they are still working and are still bulletproof (they must be atleast ten years old). I would buy the BG 60 if I were you hey, and load it with about 18lb line. Should go nicely with the shad pro 11ft that you said.
Oh ya just wanted to note: The alivio is a graphite frame right? Well with big reels that are made out of graphite, they tend to twist and this gets annoying. So stick with metal frames when using bigger reels, thats why the BG 60 is also nice. Its metal, and doesnt flex at all, so energy isnt lost through the twisting of the reel. Its also very well priced and will deffinetly last you over 10 years if looked after
