Broken tip
Waverunn3r
Hi all
I broke the light tip of my elbe wave runner not too long ago and was wondering if it needs to be replaced or could it be fixed. It broke about 7 - 8 cm from the bottom. The 2 peices when put together doesn't look like there are gaps so there are no small pieces gone.
What do you guys suggest?
Walt
Hi Waverunner!How did rod break?The better 2 options in my opinion is to switch to a medium tip(Is it a 5piece rod?) or replace it with another from your supplier who perhaps can order the tip from the dealer.I see you're in Cape Town.Suburban have baskets where I've noticed there are odd parts of rods,etc,available.It's unlikely you'll find that tip but it's worth a try.Phone Peter At suburban and ask him.Try other suppliers as well.I've patched up a bust telescopic rod by inserting old piece of rod into both sides of breakages after cutting both ends flush.Then superglued both ends with old piece rod inside.But I have no faith in this working,as I haven't even tried it for fear of rod breaking and losing a fish.It's very unlikely that with such a big rod as your waverunner that it can be repaired.Just getting stuck would probably cause it to break again and if something big latches on you could lose reel as well.
What's the Waverunner like wrt to casting and all round ability?Have been considering buying one but no stock.Cheers!
Waverunn3r
Hi Walt
Thanks for the reply. I broke the tip fishing a HUGE piece of seaweed:(, but don't tell anybody lol.
The waverunner is an ok rod. A bit on the heavy side. I cast a 6 ounce sinker comfortably with a decent size bait. Unfortunately it only comes with a light & heavy tip. I asked Johan at suburban for a price of a new tip, but i'm still waiting on him to get back to me.
Polychaete
Ive a slightly different take and have repaired many broken rods in my days.
I can't judge how bad the break is or if using it is going to cause further damage, maybe a photo can answer some of those questions.
In 70% of situations you can adequately repair a break so I would not necessarily spend money on it...........
Weedeater
[color="#006600"]Waverunn3r[/color] wrote:
Hi all
Hi Waverunner,
Contact Akals in Dbn on 031 313 2000 or david@midas.co.za
Akals are the suppliers, so they should be able to help you with a new tip.
Good rod btw, I have one as well.
Waverunn3r
Thanks weedeater.
I wasn't able to take a pic of the broken section last night, but will definately do it this evening
Walt
Waverunner- It's a bit difficult judging it by photo without the benefit of having rod in front of you.Judging by using your fingers in photo,what you could do is take it to someone/dealer who offers repairs and find out if that piece,minus the 7 or 8cm,can be built up to fit into your mid piece.If yes,rod will be stiffer as it's shorter.But at least it then can maybe used.I know of a repairer in Southern suburbs who has an angling business and isn't a part timer.If you want phone nr, pm me your phone nr, and I'll phone you with details.By the looks of photo,it doesn't look like it'll work if you can join the broken pieces together.It'll probably just break again.Cheers!
Polychaete
From what I see it looks repairable. It will never look nice, and probably feel a bit different, but I would most certainly give repair a try.
If the graphite is not split lengthwise, and it more then 20cm from the tip, Id try to fix it.
I'll ad a picture just now of a rod I repaired 3 years ago that I am now giving an overhaul, it caught a lot, lot of fish since then. I've just taken off the guides, and sandpapered the previous finish off.
The short back piece to the ferule may be a problem.   Where did this happen?
Polychaete
The proverbial "penny dropped" overnight! and the problem you have is that you have only 8cm behind the break, so probably not enough space to put an insert in.   That still does not rule out the possibility of fixing it with a sleeve only (the one in my picture has only a sleeve) but it is also at a fairly stiff part of the rod..........and so the debate goes on.
BOTTOM LINE (pure guesswork)
If it was mine I would most definitively give fixing a first try and I guess you would have a 70% possibility of success.   You'd end up with a sleeve of about 15 cm.
I you are handy and can do it yourself give it a try, not much to lose.
Its a big job, a labour of love because it is not economically viable to do, you would need to remove and replace the guides, and if you don't have the stuff, buy glues, finishes, binding cotton, find the right sleeve somewhere, and spend R5 per km driving around.
I find it greatly satisfying to do a job like that.
Waverunn3r
Thanks for the info Poly. Unfortunately I’m not much of a handy man so I’m gonna be taking Walt's advice of taking it to a reputable rod builders and get a quote. I've also in the mean time sent a mail to Akals for a price on a new tip (to see if it's economically viable to repair)
I must say thanks to everybody that gave input. You guys are the bestest. Sealine RULES
Polychaete
If you buy a new one, send me the old one, and I will sometime try to repair it when I have little else to do.
Then maybe you have a spare.
If you can't do the job yourself its hardly worth while to repair because it takes too much time.
