Breede River grunter
HP
After many unsuccessful attempts and hours of casting in the Breede trying to hook a grunter on a top-water lure I am close to calling it a lost cause.
Has anyone had success in this technique, in the Breede specifically?
FeedingFrenzy
It's an Eastern Cape thing!  No jokes - I've only had grunter in the Swartkops hammer Rapala that I was chucking for leeries.  And only chartreuse or perch patterns - never the silver or natural patterns.
Also in the Breede I've never had them hammer a plastic worm.  In the Swartkops they go bos for plastic worms!
It might be something to do with natural prey.  In the Breede this seems to be mud prawn.  In the Swartkops there's quite possibly a higher diversity of prey items - including gobies and blennies galore.  They will readily chomp those blnnies and gobies.  It could be that due to the heavy prawn pumping activity in the Breede (because there limited mud flats for pumping as opposed to the Swartkops) the habitat has been destroyed for the blennies etc.  There are no longer eelgrass flats in the Breede (that I know of) ereas in the Swartkops there are km's of it.
So to cut a long story short- it could just be because of different prey items in different rivers.
HP
That is the only logical explanation I have been able to come with as well. Was really hoping that someone would just tell me "No, you just using the wrong action, lure, colour, etc." Sigh, it is so frustrating seeing grunter everywhere and catching them readily on bait, but not even getting a swirl of inquisitiveness when throwing a surface lure.
Bushbuck
not personally, havent had the patience yet. But i know of someone on this forum who has caught them and cob on the zclaw. You need to go onto the shallows and work it REALLY REALLY slowly. The problem is the wind at the breede. Try fand a channel in the weed and work it slowly. I hear the goldfish sprats work well on grunter too with a small leadhead, but dont have confirmation on this
HP
Thanks Bushbuck
I hope that that-someone replies to this thread... would love to pick his brain.
Colour and size, never sure. I try mimic the natural baits around there, but to no avail. Targeting Leeries and Kob is plenty fun, but I want that grunter!
Bushbuck
U need the 9cm zclaw, im sure any small walk the dog lure would work, but dont try mimic the natural bait. its much slower with long pauses.
HP
Ja, I have tried it the way the guys catch them down in the EC, with one or two twitches and then letting it rest. How long would a pause be about, 3 seconds? What do you recon the optimum color would be?
SPIN A HOLIC
Dont give up HP. Ive caught them down to still baai while on business trips. Conditions there must be almost the same as breede.
HP
Thanks so much for the reply guys, and all the PM's.
Much appreciated!
It seems that persistence is the key here. Will give a full bash after winter again and report back with all the success ;)
jonni
There is a 4cm walk the dog stick bait made by loomis. The grunter kill this lure in the kromme. It seems to be much more effective than the bigger ones. In fact I have caught silver dollars, stompies, steenbras and small garrick on the same lure, while targeting grunter. i use the blue/silver colour.
Flippie
Whe usaly get the grunter on the fly on the mud banks but the water and wind conditions must be correct and the type of fly also.
It is top water flys called the Flipper whe use a green/brown foam with a little flash and a olive green tail. it looks like a prawn swimming away on top of the water.
whe use a figure 8 retrieve this is a very slow retrieve.
HP
Dankie Flippie, wat is die regte water en wind kondisies?
Flippie
As die Suid Oos waai dat dit klap dan gaan soek ons daai baaitjies wat stiller is aan Witsand se kant maar dit moet moder baaie wees die water moet stoot en stil staan en dan weer begin sak dis wanneer ons die beste resiltate gehaad het.
Die water moet nie soos n spieel lyk nie dit moet n chop he
Maar die trick is maar om baie geduld te he en baie stadig jou kunsaans in te bring
Conrad Botes
Hi HP
Grunter are regularly caught at Breede on topwater fly. Like Flippie said, small gurglers in tan are used. Craig Thom caught 3 grunter in one session using a floating prawn fly of his own design. (Checkit out at his shop, Stream X in CT)
Personally I have not caught on topwater flies, simply because there are other flies that work much better. But topwater grunter is definitely on my bucket list!
malcolm12m
Grunters are not surface feeders they feed at the bottom of an estuary very few places and times you can catch Grunter with a surface lure if you want to attempt it go to the swartkops river in the earstern cape where you can use poppers
xtc
grunter on top water lure is definitely not limited to swartkops - spent a fair share of my time catching them there off the top when I still lived in pe and we had a ball doing it - have now moved from pe but off the top of my head can quickly think of 10 other rivers I have caught them using top water lures other than swartkops - actually so far I haven't fished a river that holds grunter where it doesn't work - some places are however easier than others -
HP
Thanks guys. Yes, I realize it isn't easy catching grunter on top-water lures, and I get that the Swartkops seems to be the place. But my aim is to get some on surface lures in the Breede. If it was just about catching them I would use bait, but I enjoy the skill and art involved in the challenge; working out a plan of action and then seeing it come to pass.
I am sure the advice I received on all the PM's will help me get my 1st on a surface lure in the Breede.
Appreciate the responses.
