BRAKE COLLARS
Polychaete
[color=#006600]Deon Brits [/color]wrote:
[color=#006600]Polychaete[/color] wrote:
[color=#0066cc]Reefman[/color] wrote:
There is def more control with the collars on...
I think that is the issue.   Most cast control mechanisms make casting easier, but I have serious doubt if it will make a competent caster cast further.   I tried experimenting, but found those things hinder me to the point where I have to completely change my cast.
Howzit OOm Polly
I have found with the saltist 50 if you have both the big collars with flat side against the rim that they seriously brake your cast.
Then i took them out and swopped to the black ones (this was on a friends reel who struggled getting 100m) then wham, it upped 20m. But the spool was still controlled
Dankie Oupa Deon!
I will first play with the Trini DC as soon as the weather in CT gets a bit friendlier.
I must say that if I am ever converted to using a cast control, it would probably be a magnetic and adjustable one.   Things that effect my cast are issues like wind, the number of casts I have made for the day (effects the lube in the bearings) speed at wich I need to cast.   This changes continuously and may require adjustments to the way I cast and occasionally causes a small FU.
When you have another social Ill bring my rod.
Johan S
Deon, seems like Allan has been helping out a couple of guys :) I've recently also returned my two red brake collars with the conservative 2x flat sides setting. Have significantly improved my distance, now that the confidence is up. I just don't throw overwinds anymore, which is perfect! Well, no overwindes in the last 50 casts. Thats reason enough for celebration. Allows me to concentrate on other things. I'm casting a much looser spool now, and I still feel that the sinker is not peeling the line of the reel fast enough. I'm going to have to change the break configuration. I just want to have a go first at casting big baits (well, a bottle to simulate it) and see what difference it makes.
Walt
Hi Deon!Worth looking and trying the single collar as you mentioned.Makes sense in that with the slightest hint of an overrun,it'll slow spool down whereas collar will govern spool.Fished in social Saturday,and I fished like Queen's rendition of 'I want to Brake Free' with no collars and had about 2-3 tangles all day as i have my finger ready.But I feel the WIND factor could play a part with the brake collars out,as wind will slow sinker down while spool will run at full pace.And this could be when collars 'come into the reckoning' to prevent overruns.Just as a matter of interest,were your findings based on 1 cast at a time for each test?Reason I ask is that my casts always vary and sometimes from 5 to 10 metres per cast.Cheers!
Hooch
Very interesting read there Deon, makes one think.
I recently got myself a second hand SL30 from PieterH that he bought in Durban. Didn't check the reel or opened it, just filled it up with 0.40mm Daiwa Tournament monofilament and Moz here we come. Arrived at Moz and the very first cast i made with this reel were a serious overwind. Adjusted the cast control nob, to no provail. Well i adjusted my casting style for throwing plugs and spoons (Thanx Ryan) and were getting around +-100m with a 4oz plug and 12ft rod. The overwinds become less and less, but i had to have full control by using my thumb to guide the spool. That thing were spinning like crazy. When i arrived back home after the trip, i opened the side plate. And guest what? The brake collars were removed all together.
Now should i put the brake collars back on the SL30 or just leave them out all together. Maby every 10th cast, i get a slight overwind, but that is fixable in 30sec.
Psy
Reefman wrote:
Interesting Deon...! Strange though that your best cast was with only 1 brake collar...
Strange that you should be discussing this topic.... this last weekend, I removed all the brake collars off my Saltists... just to try and see... had a few more nests than usual, but whacked one 170m!
Hey Doc...hows tricks? chucking that lead away hey !!!!.......with the saltiga30?
funny hey...i took them out then fitted them back in.....definitely more control, now i can afford to 'watch' the spool moering the line out !! no overwinds @all. ......@ Deon - But interesting to see that one collar only used and a larger one at that? I thought use of the larger black ones would slow the spool more, seems like the opposite? And which way ought the collars to be fitted? as in the picture posted...or wot?
Do you ahve an explanation for that, (im not an engineer, only a captain)
thanks for the post - this is interesting guys!!
Durran
Two obesrvations:
1) As Johan S said, the collars gives him more confidence and allows you to put more force into your casting resulting in the increase in distance, not the actual collars
2) Would applying one collar not cause an inbalance on the spool...law of physics?
SAfish
I recently bought a SL30 and have been struggling with over-winds. I fished today and no over-winds, but I was very care full and not casting hard. I got a grain of sand in the reel. I opened the reel, only to see that there were no brake collars fitted. I looked in the box and there they were. There were red ones and very small transparent ones, but no black ones. I installed the red ones with the rounded side facing outwards. I can't wait to go and make a cast tomorrow. My confidence is up already.
Notice to all new SL30 owners: open the reel and check if the brake collars are in!!
Thanks for a very help full thread!:clap12::slr::
SAfish
I went down to the water this morning to pump some worms and I took my rod with me. I made a few casts and the difference is unbelievable. I had so much more control and I could put more power into my casts. My cast control is fairly tight and I could only manage between 80-90m. I know I can get more distance, but hey, it is a start.
Walt
Hi SAfish.You were mentioning overwinds on the SL30.My experience was as soon as I fished with Hi Visibility line I got overwinds all the time,as opposed to standard double x line with no overwinds.So,switched to Suffix XL strong but not Hi Vis line type, and seldom get overwind.So,just wondering if you're using Hi Vis line,as this could be reason for overwinds,as i throw so much further without the brakes in,and without Hi Vis line and no brakes I get no overwinds whatsoever.I've since thrown the Hi Vis line out as it was happening with both my Saltist 30H and Tor14.Could be something to do with die or colouring in Hi Vis line which makes line drier and kinkier(Not referring to vulgar connotations,lol),which would work better with brakes in.If not using Hi Vis,then keep the brakes,as perhaps some reels operate better with brakes in.Just my 2c.Cheers!
Sylvester
Banned
I was an over the shoulder caster since first throwing a multiplier, about 25yrs now. Since last year July/August I have been fishing with a guy that is arguably the best thrower of BIG baits in WP (cow baits regularly sore over the 150m mark and straight sinker is over 200 with 1mm leader and 0.50). He has been giving me pointers on his casting technique. The first pointer was to throw the cast control out of my SL50. This immediately gave me more distance, control was a b!tch at first. i have now switched to fishing only Toriums and there is no cast control in there, plus Keith Murison has done his magic on the spool shaft, and my distances are only getting better. The point I'm trying to make is that the cast control works if you are struggling with overwinds but once you have an educated thumb then best let that spool spin with only your thumb to control it. Agreed the casting champs all have some sort of cast control but they could only have a certain number of casts to register a distance and would not want to waste any on overwinds. We on the other hand are not limited to a certain number of casts, well that depends if the missus is with or not!
Hooked
Yes bru but the oke you refer to is a freak,,,,,,,,hahahahahaha
I have cast with him a few times over grass and I can tell u honestly that if he actually spent some time on his technique and bought a decent rod he would give danny moeskops a run for his money.
Every time he touches that spool with his thumb it robs him meters of distance,He can afford the loss but many peeps cant.One day I am gonna steal Rodbuilders Benq Abu and put it in his hands and see what he can do.
SAfish
I am not using hi-viz. I had Okuma Platinum on it, 10.5kg 0.4mm. I now changed to Kingfisher 9.1kg 0.4mm line. The Kingfisher is thicker than the Okuma, but it is softer. The hardness or softness of a line plays a definite role in my casting performance. I forgot to mention, I am using a Sensation shad pro 10ft rod and a 2oz sinker. It is a lovely rod for casting plugs and spoons. It is a little short and not stiff enough when it comes to fishing with bait from the beach. The rod is rated 2-3oz and I am struggling to keep my sinker anchored when the water or the current is a bit rough. I am going to buy a Exage 12ft with the 3 tips, then I can change it the way I like it. I will then be able to throw a much heavier sinker. Any comments would be appreciated.
@Walt:  Hi-viz + kinky = prostitute line :headb::rofl:
SAfish
I learned how to cast with a old Pen 49M. I later fished with the old red Penn 500 Jigmaster. These reels were very unsophisticated and all you had was your casting technique and well educated thumb. About 8 years ago I stopped R&S fishing due to medical reasons. I fished only in the lagoon with my Abu 6500 C3 and I am now trying to get back into the game. My 10ft rod is way different from my previous rod which was a 13-14ft Blue Marlin that is now 21 years old. It started off as a 14ft but the tip broke twice. I am going to use the cast control only until I have educated my dumb thumb again. Btw, I can't cast with a grinder!!!
Sylvester
Banned
True!!!!....ROFL!!!!
Very impressive to watch him in action though!
