Braids
Jacquesdw
Hi What are the best braids available in South Africa? I am looking for 10pd, 15pd and 20pd. I would prefer the 20pd to have some abrasion resistance like Suffix 832 but that stuff is pretty thick. I am currently using Mustad UltraBraid from a couple of years ago.
Had a couple of casts with a set-up with Gesox braid this weekend- awesome stuff. But then it was also paired with a GraphiteLeader rod (rated from 1/32oz) and limited edition Stella (1000 body and 2000 spool) I have to say that casting with that top end Japanese set-up was just plain spectacular. The difference, what felt to me, was that the lure just accelerates with no effort and then keeps on going, and with excellant accuracy. Think Volksie vs Ferrari! There is no going back.
Simen
I am a Fireline fan, more expensive YES, but last longer and is good quality.
Also it is a rolled Dyneema fibre and not a woven braid
G
Guest
Guest
Of one thing you can be sure, there is a lot better braid around than fireline. Fireline is create for abrasion resistance  as we all know it breaks well above it stated breaking strain. It is however thick for its breaking strain - even if you consider what its true breaking strain is.
One needs to decide what you want out of braid and then look for braids that cover these bases.
If Diameter is important to you - look at:
X 8 YGK Castman
New Gatorbraid
For light stuff - Berkley Nanofil
Saltiga Surf braid - great casting baid - Zero Abrasion resistance
Varivas has brought out an affordable casting braid - I have not tested it as of yet.
All Purpose Braids - Where there is a good balance between diameter - abrasion resistance and breaking strain.
Jerry Brown - Solid
Power Pro
Rovex - Viros - very underated stuff
Suffix 832
Suffix Depth Finder Braid
I do a fair amount of plugging off of the rocks so abrasion resistance is of importance to me. I would also think it important off of a boat where a hooked fish can swin under the boat. The result is that I tend for the second batch of braids with Jerry Brown being my preferred brand at present due to the value it presents.
I do however have a few spare spools filled with YGK and Nanofil for when I fish from the beach. The need for abrasion resistance reduces and the need for thin diameter and longer casts increases.
There are of course many more braids and everyone is likely to have their favourites but this should be enough to get you started.
All of the above is based on the assumption that you will not be fishing over 40lbs. Above this strength and there are a number of other to start looking at.
Regards
Anton
Simen
X 8 YGK Castman
New Gatorbraid
Jerry Brown - Solid
Power Pro
Suffix 832
Regards
Anton
Haakies, Fireline is not a braid, its something totally different
Jerry Brown - Solid
Power Pro
Suffix 832
Are all braids
Fireline is a rolled fibre not a woven strand.
G
Guest
Guest
I am aware of the difference between Fireline and Braid. I used Fireline for years before changing to the others.
In my opinion the construction is of little consequence as in most cases one would be using the line for the same application.
Fireline remains thick for its breaking strain and this coupled with the fact that it fluffs up after a while make it a generally poor casting line. It is a great pulling line due to its understated breaking strain.
I am looking for the best of both worlds and hence my suggestions. It is not bad stuff - there are just far better options on the market.
braailegend
I only use Powerpro, have not used anything else, so can't compare it, but PowerPro never gave me a reason to look at other options. It is a bit thick though for its rating.
Fish all styles with PowerPro, Light tackle, Spinning, Carp, Backing and mainline for R&S fishing
Jacquesdw
Hi Thanks for the replies. I decided on Power Pro Super 8 Slick because I would need some abrasion resistance and but have the smooth casting of a 8 strand braid.
Just bought some on eBay on the following link (store was recommended on a SA bass fishing site)
http://stores.ebay.com/James-Tackle
3 x 300m spools for R750 (incl shipping):SSS
Regarding Suffix 832- I have 1 reel spooled with it and am very impressed with its toughness. Just very thick for braid. If I had a deep pit reel it would be great.
YGK make awesome braids but apparently you really have to know your knots as it is slippery.
Have a great weekend! Off before the crack of dawn on a reccie on some good coast for some cob on artificials. The spring low should get them holding in holes and channels.
G
Guest
Guest
Good luck. I am interested in the Majorcraft rods you are getting. It would be great to get your feedback on them. My feeling is that there is a whole world out there beyond the Excellors, Aerocasts and Airs. The price is not too dissimilar either.
Anton
