Braid
Hi guys,
We often look at the price of braid but never bother to discuss the no. of plies. A 4 ply braid is square in shape where as an 8 ply braid has a significantly "rounder shape. The 8 ply also has a greater surface area so size for size is much stronger than a 4-ply. That makes an 8 ply a much better quality material and hence the bigger price tag.
1. My question is, do you order braid by size or by breaking strength?
2. What colour is the best all round? Does it matter at all?
steve m
benniejordaan wrote:
Hi guys,
Both normally the best breaking strain to diameter or for casting just Fire line by breaking strain
I normally use green but really dont think that it matters it is just that most braids are avalible green
And also thanks for the info on the the ply You learn somthing new every day
Simen
I did a write up on braid awhile ago trying to explain the choice of braid, but what it comes down to is choose braid on the dia and not on the breaking strength.
Will look for the tread.
Simen
Taken from diffrent tread-hope it helps.
Homie- Dont know where to begin with the advantages and myths surrounding braid.
But here are a couple of things ( my opinion ) what you should do to make your braid experience good.
Multipliers first:
Dont think that because braid is so strong that you can now fish with ultra thin line. This is where most guys make the mistake by thinking " I have 30lbs line on my reel and then let me buy BRAID with the same LBS." You end up with the same breaking strain but with a dia 3 x thinner.
Now you end up with the top layer of line biting into the bottom layer. You cast - the smallest of overwind and braid snaps -- That thin dia cannot handle the friction and heat caused by the lines overlapping with an overwind, and simply burns off.
Between the bricks, even with a leader the smallest of nick, and next strike--- snapped. Nothing wrong with the line--( thinner line-- less body for protection )
Using to thin line creates the best of crowsnest you can think of, as explained above the thin line will snap--now it snaps and burries the point between the bottom layers ( HAPPY FISHING )
My suggestion: Your top casting section of your braid should not be to thin.( if you are adamant in wanting more line on the reel, use thin dia for backing ) Dont scale down from .50 mono to.18 or .2mm braid. Scale down to between .28mm and.32mm. This dia has much the same CASTING caracteristicks??? as the mono you are used to.
The cast, the overwind, the pull on the rod will be much of a muchness.BUT still has all the feel and directness of braid.
Also when striking you move your rod tip so little guys around you dont even see the strike.
The reason beeing, that mono stretches as much as 10% -so you cast 80m you have 8m of stretch. Your rod is 3m, if you level it and strike it up 90 deg.
Braid does not stretch-- so if you have the same action you will actually move your bait 3m, and also strike the hook out of the fishes mouth.
Small jerk on the rod is enough to set the hook 30 to 50cm.
Spinning reel
Here you can go for a much thinner line as your chance of throwing a overwind is 0.
However you get wind knots. That means the line is leaving the spool faster than what your weight is travelling away from your rod.
Some reasons for windknots--
Spool to full, line not wound tightly, weight to small to match rod, first and second eye of rod not big enough compared to dia of spool, leader knot to large and slowing down between eyes ( much the same as weight vs rod spec )
Now to overcome these windknots is very simple, and this I learned from freshwater angling where you sometimes fish with 8 to 10 lbs line ( even thinner ) in high winds.
When casting you know you use your index finger to hook the line and then release it with the cast. Now use the same hand/finger after you release the line and place this finger on the side of the spool-the line now exits between the spool and your finger. You have the same effect as with a multiplier -- You now keep a slight tension on the line-just enough needed to stop a windknot from forming.
"dont ever use braid, if you want to keep your fingers"
All I reply here is that I have been fishing with braid even before it became available in SA and have NEVER had a cut finger. That also doesnt mean it cannot happen.
You will get the same burn on the thumb as with dry mono if you apply to much pressure. You know that bad or scew cast and you want to stop everything in mid-air. DONT DO IT!!
Braid just like mono also gets " wet " after awhile and becomes more easy to handle.
Havnt written all this much since writing std 10--( 2 x std 5 )
Dont tackle non eds with brade as it is going to shake your body just as much as driving a Land Cruiser on a Salt pan in Nam ! ( sorry Homie )
Cool, thanks Simen
There is still the question of the differences in quality between 4ply and 8ply.
Another curve ball: 100% Dyneema and 75% dyneema????
Simen
I prefer the 8 ply:
More body-dont loose 25% strength if you brake a strand
More boby- displaces heat caused by friction better
Round-does not dig into spool easily
Again--absorbs and displaces heat better when knotting
Dyneema- I only use Fireline so wont try that question.
Homes- Thats a dirty one!!! I'll get you for that one!!  :fbash
