Braid
Mango
Hi Guys what or how do you ensure decent presure on the line when loading braid on a reel
I was thinking along the line of a bench vice with a cone that can be tensioned to ad preure or a old reel with that the braid is loaded on and then use the old reels drag to tension.
Simen
The best is spool it onto a spare reel and then spool it onto the reel you want it on.( after setting the drag on the spare reel to required tension)
I use a Rawl bolt with washers on that can be tightened and then popped in a Vice - the drag can be adjusted to your liking. I have these pics of the method that I learnt it from - for the life of me I can't remember where I got them and who to credit with the ownership... hope I don't step on anybodies toes... apologies if I do.
Trophy
Thats a good way, but just make sure it's a reel you don't like.
600m of very tight drag can bugger the drag washers on some reels.
It can take two of us an hour to spool 600m of braid. One winds the reel the other holds the spoon over a screwdriver using a cloth as a break.
Osie
I like the idea, is there some way or something than can help you messure the lenght of line you are spooling on the reel?
Homie
Yup.
Its a line counter, available at mmost tackle shops for around R100.
Homie
Mike Pike has made a spooling station.
Its 2 reel seats attached to a length of wood, and can take a line counter in the middle. Great for spooling or taking off line.
Homie
LOL,
The spooling station is at my place ! Will take some today. He did post pics earlier, will find them !
Mango
Hi Guys thanks for the info . Forunatly /unfortunatly I like all my reels so I wil go for Trophy option (ons kan K@kpraat )and then the rawl bolt thanks Guys
Mango
Hi Homie that same setup but with the Rawl bolt Idea that Simen mentioned built in will be pertfect cause then you can tension aswell
Homie
It does have a tensioning system,
and you can remove the part with the spool, and add the 2nd reel seat.
