Braid or not to Braid
braailegend
I have a Trinidad 30, usually loaded with .50 to .55 DoubleX, depending on what I feel like. Now my question is, is the backing really necessary for hunting big fish. I checked that if I put .52 on, I get just more than 300m on the reel. (Because there is less than 300m on spool left after spooling reel).
Also I'm not a pro at casting, thus I'll have +/-200m left on reel after casting (Not counting wading). Which I think might be enough to fight a decent raggy or small bronzie. Any advice from the guys who has landed big fish? I have landed a shark of about 30Kg without much effort fighting it.
Def-e-nition
I have to agree with Craig .
One Thing I've Learnt about fighting big fish .
Hunting for big In eds , Especially in the 200kg class , is like Walking into a gay bar , Reckoning you'll clean up - and a HUUUUGGE oke with a Squeaky voice and 56cm Biceps , stands up to the Batting Plate ........... In plain English- you're Screwed !!!
Stopping a Bronzie With 200M of line , you either had Mr MIyagi or Renier Nortje as your coach , or you're just Plain good , or both .
Go watch peter stuyvesant the Movie , under Reports . There've been guys with Muuuuch bigger fish on this site dude , but My video will show you what a 200 Sizer does when he doesnt Realize he's been hooked , until into the 200 M Mark .
I wanna See you put the Ferodo's onto One of Dem Trains , with 150m of Line left on your spool . I hope you got steel Balls , and metal thumbs on your spoool ......
Scarr
LOL ja stu jy is reg! BUT man or not da kick to da nuts!!! Hhhhmmmm stil works. As mens 'n dom haai kry en jy dalk so lukky is kan jy dit reg kry Kyk na die wereld rekord ons sal nooit dit kan doen nie vandag se man is nie mee die ou da s'n nie hul tegnologie was basies 'n handlyn van die kant af kan mens se en kyk daai monsters!!!!!!!!!!!!!!
Scarr
O ja en mens stop nie 'n bronsie van byt nie geniet ma die tyd wat jul saam spandeer! He HE HE!
mikesfb
Its nescessary and if you do a search you'll find a thread where it was worked out how much cheaper braid was in the long run so the 600 odd rand now may seem alot but the 2 grand you save over 2 years on that wasted 250m of mono left when you put over 300 on your reel and the fact that you can fill a reel 3 times with 1 600m spool makes it worth it and the breakoffs and burnoffs not so expensive with a new 600m of line being bought each tiMe, also dont feel pressurised into getting berkley whiplash or fireline because most people recomend it, alot of top anglers are now reccomending cheaper options like bully braid and kingfisher which are great braids and more than do the job.
mikesfb
im talking about 600m of braid when i say you can refill 3 times, oh also take into account currents, with a strong current and bow in your line you could have an empty reel with the fish sitting 250m from you just behind the waves. landing big fish without braid can be done and this has been shown, but that by experienced anglers who really knew how to put the brakes on, check the bday bash report with reniers fight, fark!!!, the braid just makes it easier for the rest of us to do it.
200ts
Hi BraaiLeg
I think braid in the long run is worth it. Not only does it give you much more line on the occasion of hooking a really big fish, but it makes respooling topshot much more efficient. If you decide to put braid and top up with 200m nylong then one spool can be used 3 times. Hope this helps
Pylstert
you can do the same with mono, just keep replacing the 1st 200m it used to work well before braid came out, but braid gives you lots of extra capacity and it lasts far longer than mono as a backing.
TOE 007
i have spooled up most of my reels with Braid backing , i must tell you its more economical in the long run , and if you would hook that triple digit fish , you will atleast have some chance/confidance in landing it . Plus some places, fishing from Bricks you have to walk your fish to a place where you can land em .
my 2 c
braailegend
Dit maak nogal sense om net die boonste lyn vervang, want selfs mono is nogal duur deesdae. En na 'n dag tussen rotse vang is dit 'n moet vervang. Baie dankie vir die advies.
vvt_freak
please allow me to sound a bit daft here.
how did other guys land big in-eds back in the before braid and before reels that could be spooled with 600m of line?
Very few big ineds were landed with reels holding 400-600m of nylon, Raggies, yes, Bronzies, Blacktips tigers, zambezi's no
Then they used Penn Senator 4/0 and 6/0 and used Dacron as mainline or as backing.
In the earlier days big KP's holding up to 1200m of 0.80mm nylon did the trick or they simply used flax line, cotton braided lines.
I remember watgching eugene Beukes being spooled on a Penn555 when his 400m of 0.60mm ran out within 5 min of the hookup. He waded a good 100m into the surf after the fish and was pulled of his feet a few times only to landed a Bronzie that weighed in the 60kg class
guy4245
Guys Please advise
I normally only fish for Ed's, mostly Rock n Surf, i have been using 10KG mono, i am wondering what the benefits are to using Braid for rock fishing?
mostly catching Galjoen, Blacktail, crackers, cob etc...
also can someone explain what the "backing" is that all refer to?
thanks
guy4245
Guys Please advise
thanks
Simen
guy4245 wrote:
Guys Please advise
thanks
The biggest benefit of using braid is the directness of the line, meaning if something nibbles on your bait --you feel it.
Works great for catching edibles.
Backing means, the line (braid) you add below your topshot (mono).
Braids dia is much thinner than mono but the kg breakage is much higher, so you get much more thin line on the reel than thick line.
What you will do then is first fill ( leave space for amount of mono you want on top)your spool with braid (thin dia) and then add the mono on top.
You could eg. normally only get 300m of mono on your reel now you can get 300m braid and 150m mono on the spool.
Not generally dont do this when catching edibles, more for sharks where a lot of line is required.
200ts
guy4245 wrote:
Thanks 1 more ?, why add the mono at all, why not just braid?
Hi Guy, problem with just adding braid to a multiplier is you stand a real risk of losing a finger if you get an over wind. You could use it with a coffee grinder. I tried it with a coffee grinder and it is brilliant. I know some guy is testing braid only with a trini DC so far he still has his fingers in tact.
200ts
Hi, I would suggest speak to Enigma. PM him, he Stocks Jerry Brown braid and I think he is nicely priced. Im sure he can advise you on the diameter that suites your needs.
