Braid on multipliers and coffee grinders
Mike Pike
I had the pleasure of casting a fellow members Torium 30 loaded with casting braid at the recent GP social, very impressed indeed , couple of questions though :
1. should one spool up the reel with braid only
2. topshot{mono} and then braid
3. knot to use between the two,  bimini on both and catspaw to join the two
4. braid to leader , yucatan.
5. Will normal backing braid work on a coffee grinder or should one use casting braid as well.... this will only be used on scratching setups eg gw40/ sa40/ bg20 / bg 30/ Torium 30 ... all replies much appreciated, shot okes !!
