Braid/mono
Mike Pike
Hello all, have decided to add braid to my reels at last !! couple of questions though , 1. using 50 lb , 0.34 mm braid and 40 lb, 0.50 mono is this a good match ? going to do this on Saltist 40 and SL50 , I know the advantages are increased line capacity on both reels , but how much braid and mono is a good ratio ?? as line capacity for reels is always quoted for mono !! thx okes any input / help much appreciated:?.
Mike Pike
Thanks Whaler , Berkley a bit pricey, going to use Pioneer/palladium power ? dont know if its a good braid or not ? um its in 300 meters how many yards is that ? thx. mike.
Weedeater
Hey Mike,
How you mate? Have a look at PowerPro (http://cgi.ebay.com/Power-Pro-Spectra-Braid-50-lb-1500-yd-Moss-Green-New_W0QQitemZ220258130758QQihZ012QQcategoryZ31706QQssPageNameZWDVWQQrdZ1QQcmdZViewItem)
as well, worked out cheap, has a diameter of .34. I put 400m on my Saltist 40 (Whiplash that was from my Saltist 50) and will fill up with mono.
I got 650m of 50lb PowerPro on my Saltist 50 and the remainder will be filled up with .50 XX. The more braid the better.
Mike Pike
Hey Weedeater how u keeping ,thx for info ,will spool up saltist with what at the moment which is 300 m braid and the rest mono and do the sl 50 some day with braid and mono. thx boet regards mike .:).
