Braid loaded wrong
kalf
I have been getting a few wind knots every now and again. Noticed my braid is spooled the opposite way to how is recommended everywhere ive looked. It makes a hour glass shape, but the taper should be small on top and bigger at the bottom.
As far as ive read the hour glass shape cause the smaller loops at the bottom to pull the bigger ones above off to quick and that causes wind knots, i know its not the only cause just want to remove one problem at a time.
Now my question, i read somewhere on the site that some reels come with extra washers in the box so you can adjust the spooling shape, think it was neilg. Does anyone know where you would put these washers, above or under the little gear on the shaft? Didnt get the washers but can make some.
And does it improve the shape?
Tope
Take the spool off and place a small washer on the shaft and replace the spool and respool the braid should work fine
