Braid/fireline advice
FAF88
Hi Guys. I'd like to use my Speedmaster for targeting smaller shark and ray species. Could you please recommend what make, diameter and breaking strain braid I should use for backing? I've also recently bought a SL30 to pair with my 110H which I'm planning on using for targetting Musselcracker and Galjoen, what breaking strain Fireline should I put on this reel? I've never targeted Cracker before so I have no clue as to what strength line I need... Thanks a lot!
Turns123
Hey bud
Not sure what braid backing would be best - whiplash is good but pretty expensive - might be some cheaper alternatives that still perform well.
With regards to casting braid - get the fireline in 30lb - i've got the smoke colour. Diameter is around 0.38mm i think - but its potent and definately worth it.
Anything heavier wont compliment that setup.
Sweet
FAF88
Hi Turns. Thanks a lot for the advice! Will definately get the 30lb Fireline then! Anyone else with a suggestion as to what backing to use?
jaccil
50lb Whiplash (0.17mm) is used as standard backing by most ined anglers. I have 35lb (0.12mm) backing on my one edible reel.
As for using Fireline as topshop to target musselcracker, you may have a bit of a problem with 30lb. Hannes101 hooked some crackers with braid earlier this year, which snapped on the take. I've been using the new Fireline Radial braid in 50lb (0.35mm) and 80lb (0.45mm) and caught most of my galjoen this past season with this braid on my Saltiga Surf 30. Unfortunately I've not hooked a cracker on this setup yet, but that's the idea!
When using braid as top shop, also consider the rod you will use. Firstly, you will need rings that support braid use - braid will damage softer rings, which in turn will damage the braid. I also would recommend not using a really stiff rod. I use a very "forgiving" rod, which helps in playing a fish with braid (no stretch). The light tip of most multi-tip rods should do the trick.
FAF88
Hey Jaccil. Thanks very much for the response! Looks like everyone recommends Whiplash so that's the way I'll go... Thanks for the heads up about the Fireline, think I'll look into getting the 50lb as well as I'd hate to lose a Cracker!
FaF ,
I also use braid for topshot on my light setup. Like jaccil said,braid is very direct! You margin of error is very small because there is no stretch. If you hold the fish  the hook wil pull.
FAF88
Hi Simen. Thank you very much for that informative post! I had searched before posting my topic but hadn't found that one... I'll be fishing only with circle hooks for in eds so at least I won't have to worry about how hard I strike, but I'll definately keep that in mind when fishing for eds as I haven't yet progressed to fishing for eds with circles...
FAF88
Hi Armand. Are you using circles on your light setup or J hooks? Would you recommend that I rather use circles when using Fireline in order to decrease the risk of pulling the hook out when striking a fish? Has anyone had success targeting Cracker with circles? I know the guys have lots of success with Gallies but I haven't heard of anyone targeting Cracker with circles.
Koper
Armand steenkamp wrote:
Hi faf,
Never used circles with braid. Im gona try it tomorrow and let you know.
Slegte nuus faf.........
Hy gaan more useless wees, gaan mos hengel saam met sy nationals spanmaat - 'n jonge dame, gaan tien teen een vergeet hy het sirkels aan terwyl hy met die tannetjie ginnegaap, as dit vis byt dan kap hy daar vas::S!
Ok ! Circles worked gooood! I only caught flatfish. I missed 2 pulls but i think my bait was to big for my hooks!  With the braid I fished with a light drag.
