Hi All please help?
This weekend I went and bought two Shimano 10000 GTEs and two rolls of braid(25lb/0.26mm Sufix & Rovex)
I made a line-tensioner with a threaded rod,2 nuts, 2 washers and 1 spring.Worked quite well to keep a constant tension on the line while the wife does the holding(off topic).
Problem:
According to the line diameter and capacity reading on the spools, I calculated that it should be able to take +-640 meters of the 0.26mm braid(if my math is correct).But as the line measure shows it only took 360 meters - 240m short of my calculations.Any ideas what might have caused these inconsistencies?
Pictures to follow.
Problem:
Pictures to follow.
