Braid backing
I'm sure this topic has been covered....but here goes!
I have a Torium with Power Pro 50lb Backing on it. It has been on the reel for 4 full seasons and heading into its 5th. It has not been abused, over bricks and structure etc., but has seen a fair bit of water in that time.
Question is do I.....
1) Replace and discard old braid, maybe use on grinder in reverse.
2) leave it and hope to hell it doesn't pop on a big fish?
3)Try to inspect it for any defects by spooling off and re-spooling. Bearing in mind it would take an eternity to inspect it metre by metre!
I am keen to hear you opinions of some guys in a similar situation.
Moyeni
What I normally do after I have fought a big shark or edible and they have taken a fair bit of braid. I always go to my local tackle shop and have them re-spool the braid back on tight and evenly. They always inform me while waiting if there is any damaged braid (rotten, nicked ect)
Good question. I have 750m of 80lbs on each of the Trini 50's and Tor 50's and although I don't fish them as much as you get to the fact that I do a lot of kite fishing and swim a bait whenever I get the chance so the braid is in the water for long periods of time.
I have Whiplash on 2 of the reels, Power Pro on 1 and Jerry Brown on the other and also going for 5 seasons.
I have gone to the trouble of respooling each reel after each heavy trip removing the line to a 5th reel on an eletric winder mechanism and then reel it back under 3kg drag taking special note of the braid that has worked the hardest (top 200-300m)
After season 4 and a few good tussles with bronzies and OTHER sharks I went as far as testing the braid to 65lbs on a line breaker (wasn't keen to sacrifice R2.40 per meter) on the Whiplash every so often along the 600m length and the braid passed with flying colours, even though it smelt like a wet puppy (lekker miff) I then tested the top 5m by stitching loops and breaking it on the machine and got a consistent 86lbs break.
I believe that your Power Pro (really good stuff) if not run through sand banks or across a reef should be 100% or at least 95% and should it have significant damage you would see it if you respool the braid.
Initial input cost on good braid is high but the long term saving on nylon (2 or 3 spooling from 1 600m)and general longevity means that you really do get full value for your money.
Dave Batista
Nice thread CVDP. Interesting.
@Enigma whats the reports been like of the 50lb 4-strand HMP backing braid? Just put 600m onto my Finnor 30.Whats the longevity like compared to lets say 50lb whiplash? Oh and what you rekon about the 48lb Bully braid as I got 600m on my Tor 30.Paid R500 for the bully and HMP braid.
Sorry for the hi-jack CVDP.
Can't comment on the Bully braid as I have never fished it.
HMP on my Tor 30's going strong and the 50lbs on the grinders is holding up well after 2 seasons but I don't get to fish it nearly as hard as the KZN guys do and they seem very happy. I've been out on a few boats using the 130lbs on the KP's for bottoms, commercial and recreational and they been fishing it 3 or 4 seasons and they are super chuffed.
All i can say the HMP is really good braid, manufactured by world leaders in parachute chords. Reason for it being so cheap, they refuse to involve a middle man so they manufacture and distribute themselves.
Sorry for the Hi-Jack CvdP
Katot
This is a hi-jack, sorry!! I also use the 4 strand HMP, I see there is a 8 strand HMP as well?!?!? Is this a casting braid?
Hi-jack away.... no worries! Hope to get a few more opionions on the longevity too though!
On the quality .....yip, Power Pro is a top quality product and I hope to see a season or two more with the current braid. I think I will probably re-wind and inspect the braid sometime in the next month or so....while I am still chair ridden!
Dave Batista
Craig Van der Poll wrote:
I had an op on my foot to rectify an old cricket injury. No driving and worst of all no fishing for 3-4 months!
Jeepers that must suck, I was unable to do any fishing for 3 weeks and I was suffering from depression. 3-4 months must really suck but then at least when it's over you can klap those bronzies.
Katot
Craig I cannot comment on backing, but the casting braid on my coffee grinder is still holding up. I have had it for a hell of a long time and no probs(+5years). Hope it helps.
