Hiya Guys,
I recently helped a fellow PE and Sealine angler to get all his shark fishing tackle ready for next Summer.
We have been going through his outfit and it was decided to beef up his tackle before we got onto his terminal stuff.
Braid is expensive so it is important to get it right straight from the start. Besides the rod and reel your braid is prob the next most costly investment and a little know how needs to be applied.
When we stripped the old topshot from the reel I was shocked how the braid had been spooled...and this by a well known tackle shop in the bay! In this case the braid was spooled far to loose and uneven. In-fact is was so poorly spooled that I'm sure the first time the reel went into the braid it would have pulled and cut in so badly that it would have parted!
Spooling braid correctly is a slow and 'painful' process and when correctly should take about an hour to put 600m onto a reel. There are shops that can spool your reel mechanically, but these are far and few between.
The two best 'garage' ways remain using an old reel and first spooling this reel first and then filling your actual reel by pulling the line from the old reel. This is prob the best way, but make sure the old reel is one you don't mind inflicting a bit of damage to as the drag system will take some punishment.
The other way is to take an old rag, wet it, and wind the braid a few times around the rag. The amount of pressure will determine the number of wraps around the rag. Get a friend to apply pressure to the rag and start the winding.
Get an even lay to the braid and take the process slowly. If both your hands don't cramp every minute or two then your NOT making the tension tight enough!
Once the job is done well its very sure that when it counts most you can be sure that you can have your braid peeled from your reel on a tight drag without any braid cutting down into the next layers.
You will also get it tight to ensure that more topshot mono can be put on the reel. The tighter your braid the more water tight it becomes and this will ensure that less water and salt can penetrate into the layers of braid.
This is how well spooled braid should come off a reel!
