braid backing for a torium 14...
craigb
Seeing that you using .35 I would use 20lb braid but also depends on your target species and fishing environment..ie rocky/sandy beach.cheers.
rbacht
You do not need more that 30lb braid for backing. That's what I had on my Tor14 until someone decided to take it :X
BigBen
Using braid as backing on reels not used to fish in-eds is a waste of money....(backing for when they set off to try and spool you)
On a T14 you shud B using it as topshot to experience the rush of those eds with direct contact of braid fishing.
What a rush>>>>;)
BigBen
demon wrote:
I'm worried about a birds nest with braid!! and trying to be economical with line.
Either stick to what you know and is comfortable or mag-it your reel to help with over-runs...
Good luck
Pylstert
AlecJ wrote:
upside with braid is birdsnest is stopped quick and removed Way easier than mono!
not always the worst one I have ever had was with braid, it was impossible to untangle, had to cut the line, lost about 150m. My leader came off on the cast, it was insane, I tried for hours to unpick it and gave up
AlecJ
Oh Ok Then I was just lucky. I have had literally hundreds of birdsnests with braid and have never had a problem normaly get them out by taking 20m of line out and done.
With mono on the otherhand I have almost always a problem.
I do not know I am stating my experience. Was the braid spooled super tight?
surfboy
I have a Trini 14 and 2 x Torium 14s.....Magit on all.....never seen a birds nest since and casting further....but make sure that your rod, reel and sinker weight are balances.
