Braid as mainline
PatrickC
1) 150m braid topshot should be fine provided you're casting no further than about 120m.
2) The bob sands should do well, its the strongest braid to mono connection in know.
3) Don't know the braid you refer to but I've been using braid on my scratching setup and its go a couple of nics in it from fishing between the bricks and its still going strong. Pulled a 40kg cow shark on it this weekend, just use a 2m nylon/ fluro leader as thats usually where the line takes the most damage.
4) Try to not get an overwind! Braid is a bit easier to control but when starring out keep the spoon tension a bit tighter than usual.
5) Dependings, but with regular fishing under normal conditions it should last atleast a year, probably longer.
Hope that helps!
Cheetha FS
Hi GC! The Team Catfish braid is a casting braid and has a coating to prevent it from flaking. Ive been useing it for a year now on a regular basis and in some spots with allot of snags. And i am very inpressed by the braid and its life span. Im useing the 50lb that is 0.33 in thickness and in voodoo green. As patrickc said rather spool with just braid and add a mono or fluro leader to protect the braid. Whe are also getting spools of 1200 yards if u want to spool the penn with just braid. On my toriums i have 600m of braid first and then 200m of mono just to save the braid a bit. On my Shimano 10 000's my extra spools just have braid and then mono leader. the bob sands knot is the best not for the connection. Also on the cast u gonna have to start slow till u feel comfortable with casting braid as it can cut u in a very bad way!
nobbles
Hi GC,
As cheetha said we have been testing the braid for awhile and are extremly happy with the results. The top shot will be fine, but as patrick said don't try cast past 120 to 130m. But as you get more and more into your speciman barbel fishing you will be paddling bait anyway. And at the distances we place our baits casting is a non issue. I like the abrasion resitance of most braids. In my experience I find it is a lot better than mono. And as far as nicks on the braid, it will effect the breaking strain but as braid is basically woven u will damage a thread of it. This won't have as big an effect as a nick on mono, just my feeling on it.
On my penns I will be running 1 with a 50lb tug o war teamcatfish braid. One with our tug o war mono in an extended test of the mono and my pride and joy tld 20/40 will have a backing of mono and a 150m top shot of 80 braid.
Cheetha FS
Gcvanheerden wrote:
Ok thanks for the inputs!I think I will get a 1200yd spool as I can row my baits out and am not restricted to casting.1200 yd is 1100 meters I have two penns and my dad has a grinder and will be getting another one to match it.I was thinking spooling the two penns with 400 m braid and the grinders 150m.Between us we now have a two setups to takes bait out 400m plus and a two setups setup for casting distances.Must I spool the penns with 100 meter mono top shot to spare it or will the defeat the object of the braid and the directness?Also a problem that I have is the braid floating,I am not sure about the team catfish braid floating but I dont want to risk it.The venue where I fish 90% of the time has boat traffic it is not alot but I dont want the first thing i catch to be a boat.Will a captive backlead and a tight line be okay?Can you please pm me the price of the packet with 1200 yd braid spool cheetahfs?
Shot no broblem! The braid wont float on the survise and aspesialy when u have bait and sinker on the other end it wont float. I have tested it and it only has a semi float when nothing is attached to it. Will PM u the price.
nobbles
Cheetha has got it spot on. The braid will naturally be weighed down by your bait and sinker so you shouldnt have any issue there. I will put your package together and send it all to cheetha tonight.
