Braid as main Line
Mango
First off guys I am also new to this if you want to or are considering doing this read these treads 1st : http://www.sealine.co.za/view_topic.php?id=20911&forum_id=1&highlight=casting+braid
Little tip that I figured out just for the newbs . When realing in after a cast make sure that you lay the line on the spool from side to side as fast as posible with decent tension.
By doing the perfect side by side slowspread of line it tends to cut in to it self under strain
 ,Also your overwinds will be easier to undo  and your line tip dissapearing among the other layers are a thing of the past
Goodluck Mango
