Boer maak n plan!!
Sailfish
Fishing the Reebok roks with leadhed jigs and plasticks, i got a bit fedup getting stuck all the time. So I bild myself a new lure consep. It works!! Outfishes the leadhed by FARRRR..Useing my Assason light HMG and Okoma magforse reel Jigs vary in 3 to 4oz and hopping them between the bricks is a charm::S::S:wfish
Katot
Nice. Can you perhaps explain what you did and what you have caught on the setup.
I have the same problem here in the Eastern Cape, have also been experimenting with "weedless" setups with paddletails but distance is a problem with my setup.
JVW
Being serious-isn't the pic upside down-surely the lead will hit the bottom first.
It is very interesting-give us some info-how,species etc.
Why I'm asking-I always fish Rheebok in Decembers
Jannie
Sailfish
Yip the pick is upside down.The plastick should show on the top. Althow the hook is mounted on a swivel it swims true. Simply made a boom and cast the lead on the one side using a half 5oz mould and fitting a hook and swivel to the opposite boomend and walla. The plastick swims 4inshes off the bottem and the sinker causes a sanddust like affeckt below te plastick. Imitating a feeding baitfish. Kob is the target fish and they love it.
JVW
Very clever idea-I like it.I have some Bass lures,which I'm certain I can modify to this. Did you get some kob off Rheebok-was it  low/high tide. Sorry all the questions,but I wanna steal your idea if I may :ifishin:ifishin:ifishin:ifishin
Or better still-can I order from you-I see on your profile you make traces
Sailfish
JVW wrote:
Very clever idea-I like it.I have some Bass lures,which I'm certain I can modify to this. Did you get some kob off Rheebok-was it  low/high tide. Sorry all the questions,but I wanna steal your idea if I may :ifishin:ifishin:ifishin:ifishing
Thanks Jason! Fishing an hour before low tide and depart only when I get chased by the waves.Haven't desided to market it yet. You wil probebly see it on te shelves now after this post I have madem. Eazy to make yourself, but I can make you a thew.
KARLR
Sailfish, dit maak nou sense.  Great idea and many thanks for sharing.
Seems you will need to make a few more than you thought.
Ek sal jou 1e customer wees.
kaspaas
My hell, Oupa Saily, dis 'n nice idee. Maar dan, jy was maar nog altyd die man vir die tipe vindingryke gadgits! LOL
Ook blerrie nice om jou weer hier tee te kom. Het al gewonder of jy nog in daai geweste is en waarmee jy jou deesdae besig hou. Het twee maande gelede daar deur gery en wou jou toe met alle geweld opsoek maar dit lyk my jou foon nommer het intussen verander.
Terloops, sal dit moontlik wees dat jy my so twee of drie van jou jongste uitvinding te maak? Ek stuur jou 'n pm met my besonderhede.
PS: Die ouer manne van SSEC:WC het nog steeds baie fond memories van een van sy founder members! Dit sal nogal nice wees indien jy eendag weer saam met die manne hier kan gaan hengel!
JVW
Thanks Sailie,name the price and I tell you what weights and how many.
Jannie
Marshie
love the innovation - well done!
Just a thought... why not use a tri swivel, tie the sinker off the one eye and the trace with hook and soft plastics off the other? The advantages of this are: cheaper, you can regulate the distance your soft plastics will run off the bottom but lengthening the sinker line and can use thin sinker line meaning that if you get snagged, you only loose the sinker not the plastic as well.
once again, well done!
Andre Laas
Barry Wareham uses a system similar to what you are describing:
http://www.basilmanning.co.za/barry-s-blog/interesting-articles-written-by-barry-wareham/throwing-paddle-tails-jerk-shad-plastic-squid-and-flies-with-surf-spinning-gear.html
What I like about the wire form is that your lure and hook will always be traveling a set distance off the bottom so it should be out of the way of most snags, and maybe in a better position for the fish to see it?
Sailfish
You just described a rig that will give you more tangles than a true running presentation of a baitfish. With the boom like rig, the hook and wait is kept from tangles with either the leader nor eash other{sinker~paddeltail}. It travels as one unit when the cast is done. The hook on the paddeltaai faces down towards the sinker when reeld in, thus elimenating anny seewheed hooking onto your rig.basically the boom proteck the paddeltail from wheed.
Kaspaas ek mis julle manne. Hier kan mens darem nog alleen n gooi gaan maak sonder om te warry of jou KaKa op bakstene gaan staan as jy weer trugkeer na jou hengel sessie.
Artchar ek maak sommr n paar vir jou.:wfish:wfish:wfish
Sailfish
O sorry vir daai een in my vorige pos. Maar dit is na my tjorrie wat ek verwys.
gotaway
Thanks Hein (old man)
would also like to order the pully rigs and live bait rigs - all with florocarbine and circles - just like before - MISS YOU and hope all is well
briljant!
Reken ek gan die prinsiep upgrade na 7oz en 7 inch paddletail vir my surf gear.. Reken dit gan taamlik multsteek veroorsaak...
