BLOEMHOF BARBEL
Krugel
I am fishing the Bonanza from the bank this year. Thinking of what length rods to pair with my SL30 Daiwa's. Most of the baits will be taken in by Electric Rubber Duck(will be to big to cast lol). Range will be +/- 300 Meters out.
Suggestions?
AYOBA!
use a fish finder as well to drop in the best possible spot, distance does not determine the best spot.
Krugel
I know where the old river bed is, I normally use boat rods, 7 Footers, but are worried about hooksets over such a long distance. Not that a longer rod will make a big difference I think?
200ts
Hi Krugel. If you are not going to be casting then consider using braid. You will get much more line on your reel and there is no stretch so hook sets will not be a problem. Only thing is braid is not very abrasion resistant....
Pro's and Cons I guess
nobbles
Hi Krugel,
For me the rod length will make a difference, also type of line. Nylon at 300m will have alot of stretch so hook set will be tricky. Id go for a 10ft, get a bit more leverage on the fish when you strike. Also id use circle hooks, this will take awya some of the issues hen you strike as you dont have to try rip the things jaw off. lol
Krugel
nobbles wrote:
Hi Krugel,
Thx Nobles, I am looking at two 9 Footers today. Circles is definitely part of the plan as is razorsharp "skelm" hooks.
Also my 14 Foot Poseidon RS Rod is going with.
We are going to be the biggest group at the Bonanza, 25 Anglers, so between the lot of us we should get stuck in a proper fish!
Krugel
nobbles wrote:
Hi Krugel,
Krugel
nobbles wrote:
Hi Krugel,
Fishpaste
Hi Krugel,
I usually fish my TN20 gold with a 3.5oz 12ft6 Kingfisher rod and it is just a beaut! I mainly fish the vaal river and prefer the longer rod as it gets the line up and out of snags way quicker than shorter rods. I would like to suggest anything from a 10ft upwards for bloemhof and defo something with backbone so you can bully the fish so that it stays clear of other peoples lines etc. Once you pick up other peoples lines it could be game over for sure.
Krugel
I went ahead and bought 2 x Seagrand Grim reaper rods.8 Foot. Hennie Papenfus signature series. At least I can use them from my Boat also.
Do you guys know these rods?
