Blanking in winter
Hi guys!
Need some help I fished Boschkop summer I was very good there but for aome reason winter I blanked twice ons at comp and y3aterday again any advice to get me teough the winter blues. I was fahing same combos that land me fishbin summerbut no luck...stpime2stpime2
Barbelman
I could not catch one fish with my favorite summer bait this past weekend. I then tried other flavors that I also like, but not use a lot. I started with garlic, and it was just what the fishes ordered_seal1_
Always try something else if you do not get bites, even with previously good baits.
you were lucky i tried garlic too but nothing weird thing was i had allot of wind from behind and nothing.i also went super small on the baits... but a day at the dam is better than 7 at work ;)
Zombie
Stronger flavors or different ones work during winter and summer sometimes
Also consider depth of casting and pace of bites in winter will differ from summer
Found that at some spots fish are way closer during winter than summer.
Bite tempo went from 45 minutes to an hour and 45 minutes
And fish went from liking sweat favors to something like strong garlic or almond that never works during summer
Brandon p
my best advice will be use soft baits in winter soft floats etc try fish a bit deeper and when the wind picks up strongly at the vaal use a bit of onion dip over your ball sweetcorn also is a winner in winter.
That sounds perfect i remember on Schalks dvds when they fished the vaal he did a comanation with devils drag and fx and very fine and he started to get.. its realy weird how things can change in winter...((goodp_
faniedt
If wind is blowing from behind then the fish are normally deeper ... patience is also key, try to keep one rod in as long as you can while trying to work out a tempo with the other rod ... some guys leave it in as long as 3 hours
