Blakes, Strand, what lures/ softbait
braailegend
What lures softbait can/have worked around Strand area? Was using Berkley Jerk Shad and Pogy baits, They took some punishment and bites, no more wavy tails, but no bite on the hook... any tips?
jaccil
It's small shad biting the tails off and sticking with soft plastics in these conditions will become an expensive experience.  Rather use a lure with a tail hook, like a Toby, an Onde Onda, or a lipped shallow diver (rapala).  Use single hooks instead of trebles, especially when targeting small shad which need to be safely released.  There is a good chance that you will get smashed by a garrick in the process!
braailegend
Busy swopping my trebles for singles, what size hooks do you recommend and type? Usualy I use small spoons, smaller than 1 ounce.
BrendanD
Are you fishing off your Kayak or from the shore?
What rod and reel setup do you use?
braailegend
I use kayak if the swell is not to bad, otherwise I wade out. I have a 7 foot shimano rod with a shimano4000 something reel. With a 6.9kg line. I have a smaller Elbe rod if I need a extra rod on the kayak. Have not had any luck on the kayak yet.
DJP
There are plenty of baitfish in the water so the predators wont be far off. Plenty of sharks around and a few small elf landed from the reefs (and kept WTF?). They shouls of Cape spirinkies will have some shad below them picking them off, and there is always some leeries around.
Jaccil gave some sound advice, small spoons are your best option, then a small chiselnose might work when the fish feed more agressive at dusk and dawn.
TOE 007
i have taken plenty Leeries there in the past .
You have gotten some good advice , i will just add on my experiance , If theres no baby Elf around a Zoom fluke fished Texas rigged Works like a bomb , pearl whites , bit of silver flake or black fish it weightless just about a foot under the surface [keep in mind the ELF and WIND ]
Small chizelnose plugs .smallest you can find , the fish prefer a 'flat plug apose to the round ones . This has always been my 'gotoo ' lure for when fishing is tough and wind strong ,and have taken loads of fish on them , small spoon works , Bass type lures are really an exciting but expensive , option Zara spooks , Chugbugs even Dying flutters , small leadheads , in red and white , pink , Chartruse .
if you are a prepared to work hard on a Fly outfit , fish woolheadmullets , white and a splash of Yellow in the belly , and grey on the flanks . flippers , any baitfish patterns [not to big though ]
your tackle will be fine , just hang on till about Nov...
tight lines !
braailegend
Was spinning there just as summer were finishing this year, think was march?? but got two nice elf of about 500g on white plug, and schools of 4-5 was turning right in front of me as i reeled in. Cant wait till the summer is here again
DJP
Was there Sunday for a short while to test some spoons I made, water looked good, bit to much colour for leeries I think, water temp was ok and still plenty of small baitfish but no silversides, only mullet and streepies, with the usual small stumps/kolstert hugging the jetties. Think by October the fishing should be on there, but very quite at the moment w.r.t lure fishing, kob boats are sitting on there usual spots behind the backline so the fish are comming in.
Hey guys,
I guess the best way to fish the Strand area is wading out on the rocks and casting to the deeper water? Is it worth while casting from the jetty?
DJP
You can get fish from the jettie, but your best chances will be to fish the deeper channels at the back on the low and dropping tide, as the water start pushing get to a high point were you can fan cast on high tide. Once the water is high it takes a swim to get from one spot to another so better planning is needed.
