Blackdog adjustable mag.
16A yes
The 16 it will fit but level of control on the standard will be low due to the size of the magnet. Ideally you would want to set the magnet as close to the edge of the spool as possible
grootvis
Hi Craig,
So for the 16A its ok? Magnet size ok? The 16A is running on Abec 7 bearings so just want to be sure the magnet size is sufficient.
grootvis
Can i use the clicker space as this is in a flat recess and will take it closer? It also has the "large" magnet, so just before i attempt anything just want to make sure.
